Guess you missed this,
http://www.headsmartlabs.com/#in-the-news
or this
http://nesn.com/2015/01/boston-college-professor-weather-had-to-play-role-in-deflategate/
Could you please tell us where the balls were underinflated since the Refs air the balls or deflate them pregame to 12.5-13.5 PSI and then keep them locked up on the field until 10 minutes before kick off?
I have no dog in this fight since I am a Giants fan but the only explanation is the Refs probably didn't check them pregame with a guage, and the above link shows a delta of 20 degrees equal to a drop of 1.95 PSI, so that makes sense but lets not allow science to answer this question, haters gotta hate.
Originally Posted By: NHHEMI
Once a cheat always a cheat. At least that is the perception Bill B will always carry now and frankly he brought it on himself. He is always pushing the envelope and straddling the line on gray areas. He will on occasion also outright cheat such as spygate. He will look for anything he can come up with to gain an advantage and he is not against using gray area tactics. To me that makes him kind of slimey. I am not a win at any cost or by any means kind of guy. I actually stopped being a Patriot's fan because of Bill B and how he treats the players and his envelope pushing.
While the deflated balls in and of themselves are not a huge deal many people claim( I disagree )you have to remember it is yet another instance where the Patriots were caught cheating. If this was the 1st/only thing they were ever accused of it wouldn't be the big deal it is now. Seeing as it is not the 1st time they have crossed the line into blatant rule breaking, and it happened in the AFC Championship game, it makes it more of an issue for them and the league.
I also want to say that I disagree with people who say it is not a big deal and that it gave little if any advantage to the Patriots. My response to them is this, if it gave no advantage why did they do it? Someone thought it was worth breaking the rules or it wouldn't have happened. Also, breaking the rules is breaking the rules. Big issue or small they still cheated.
11 of the 12 balls used by the Patriots were 2+/- PSI under and the 12th barely met spec's while the Colts balls were all found to be within legal spec's. That means at some point someone on the Patriots purposely let air out of them. They either submitted them low and they got past the Ref inspection( if so Ref should face penalties )or they were deflated at some point after the Ref inspection and before the game. Either way they HAD TO BE intentionally set to a PSI below the established minimum spec per league rules. Once again that = CHEATING! An underinflated ball is easier to grip in wet conditions which is exactly what they had( rain )so that helps the Patriot's QB, RB's, and WR's hold onto the ball better at least to a degree and once again = CHEATING!
I have heard people try and say it was a loss of PSI due to weather/temp. Sorry but that is bull. It was 51 degrees at game time and only dropped to the mid 40's at the end. At MOST there would have been a 1PSI drop. 11 of the 12 were 2 PSI under. Not enough temp change to cause a 2 PSI drop. Plus, for the temp to really be a factor, just as with our tires, you need the temps down in the low 30's to upper 20's if not lower. 40-50 degrees will have minimal if any effect on the ball's PSI.
I don't know if this was Bill B behind this or if it was Brady. I wouldn't put it past either of them truth be told. However, seeing as neither will own up to it the coach is the one who should face the consequences if any. Ultimately he is responsible for what goes on with the team.
IMO Bill B should be fined and face a suspension of some sort. IF it is found that Brady knew he should face the same. Frankly, they both should be hammered hard if it can be proved they were involved or knew because they have lied about it since which makes it worse. The Patriot's should get a very large team fine as well and maybe a loss of draft picks. Not because of the deflated balls themselves but rather because this is yet another time they have broken the rules with the same owner and coach.
I know this won't be popular with the Patriot's fans here but I don't care. If I was Kraft I would have to start thinking about Bill B continuing on as my head coach. The guy clearly is not truly honest and ethical. He lives in the gray world that straddles the line between legal and illegal and he will cross it when he thinks it is worth it or he can get away with it. Even if he wasn't involved with this incident he clearly has established a culture on the team were people think that is how you do things. At some point the continued hit to the team's reputation and the fines/other punishments are not worth it.
What gets me the most about the whole thing is the Colts had about as much chance of winning that game as I do being crowned King Of England. There was ZERO reason for the Patriot's to cheat. The risk they took was not worth it and it has added yet anther black mark to the Patriot's franchise on the whole which is a shame. I just hope they do not win the Super Bowl. I hate to see cheaters win. The Seahawks are not choir boys by any stretch, and while I don't blame the players on the Patriot's not involved in this latest scandal, I will be rooting for the boys from the Pacific Northwest to crush the Patriots in the SB.
