Here is a cut open FL874 after only a few hundred miles of operation on a freshly rebuilt engine. As I was under the truck doing something completely unrelated, I literally WATCHED as this filter sprang a leak. First thought it was the seal but it turned out to be where the can was clamped to the base. I normally use the larger, more efficient FL1995 but figured I'd use this as a "cleanup" throw away filter. Well, I cleaned it up (see nearby "AAAKKK- Grunge in MC Filter" post but had to change it a lot earlier than planned
If you are wondering where the ADBV is... there isn't one. Not designed to have it. Beside the leak, it's a well constructed filter... typical of MCs.
