Following some of the Ford Focus forums across the internet, a number of owners use an FL842 on their Focus.
I am interested in this application, but cannot find a proper cross reference for using this filter. Is it the same filter as the Fram PH16?
If so, one advantage of using a PH16 spec is it is larger than the OEM 910 (and shorter than the FL-400, giving better clearance). However, I know the by-pass valve setting is different, which would not be good in the event of an oil-bypass scenario.
Any insight is appreciated!
