Wanted one last year. Tried the Ryobi 18v impact driver. Did not work. This year I got the Black & Decker Matrix impact driver that's corded. Did not work, but I kept it since I love it's air inflator attachment. It's very efficient and vibrates/heats up the least of all the inflators I've used.
Then I noticed that Craftsman has an impact WRENCH Bolt-on that works with the Matrix. FINALLY! I can use a tool to loosen bolts off my cars. I've tried it as high as 100lbs. It takes a 3-5 seconds of impact, but it will come loose. Also NEVER loosen a bolt without a jack with an impact. Impacts as spin fast enough that you can pop a nut right out. Unlike by hand, where you just want to crack it loose. I see such YouTube videos of impact driver reviews. Of course with the tire bearing it's full normal weight without a jack it'll be harder to loosen a bolt.
Apparently you get more power off the Craftsman Bolt-on cordless than the BD Matrix corded. Those tools are also currently on sale so you can get a cordless 20v drill and impact for less than $90. Remember, it's the impact wrench. You can tell since it'll have a male socket (square) as opposed to the impact drill which is a female hex (drill bits). I used a hex to socket adapter when I tried.
