Your the one promoting these 0 Ohm wires as something special no one else, the guy who made the video isn't on here promoting them.
There is more than enough evidence that they don't bring much if any improvement only maybe some problems. Check that!
What NGK has to say. Now who do we believe you and some guy making videos to promote his products or NGK? I will believe NGK thanks.
Originally Posted By: NGK
When a spark plug fires, it creates a great deal of radio frequency interference (RFI) and electromagnetic interference (EMI). Uncontrolled, this can show up as static in the radio or other electronic devices, or much more seriously, in electronic ignitions, fuel injection, and engine management systems. This interference with EFI and engine management systems can cause "cross talk" between wiring harnesses resulting in poor running, misfiring and decreased performance.
NGK Resistor Spark Plug Wire Sets utilize a construction method known as "variable pitch" wire winding to create resistance to radio frequency interference. The variable pitch winding (loose/tight/loose) provides suppression throughout a very wide range by "scrambling" and breaking up the electrical waves radiated by the firing of the spark plugs.
A ferrite magnetic layer consisting of a mixture of rubber, plastic and powdered ferrite magnetic materials, offers uniform resistance and unsurpassed conductivity. NGK wires have a lower resistance than conventional carbon core wires (8k ohm/meter vs. 16k ohm/meter).
