A lot of Catherham's points are mere reiterations of what Dr Haas has been saying all along.
Not sure this is the case. For example Haas pays little attention to the HTHS # but instead relying on the traditional kinematic viscosity statistics. By comparison CATERHAM as you know focuses greatly on the HTHS stat and relegates the 100C and 40C viscosity numbers to the back burner.
There are some differences and i am in no way indicating that they agree on everything but the similarities are glaring.
If the glaring similarity is "as thin as possible, as thick as necessary" then many on BITOG are like CATERHAM and HAAS?
+1, when you read Dr. Ali E. Haas's non-skin surgery work and defer to his "expertise" on Motor Oil (think about that) you should know that he doesnt fully understand the correlation between HTHS and SAE grading. So, when you read his stiff and see "W-20 in Lamborghini and 0W-30 in Ferrari," you can see that he isnt TOO far off the mark when you realize that his 0W-20 has a HTHS of 3.5 and the 0W-30 a similar, very much higher than the SAE system. i say this because when you read through his stuff and you hear about him talking abou t the "thin oil" you might get the impression that its sensationalist.. but realize that he is not talking about TOO TOO much thinner oil, or thin oil in SAE name only (he gets it wrong, or the manufacturers do? Or SAE does?).. and it makes more sense, and isnt as dismissable. He makes some good and interesting points, though he believes that cars have oil squirters when a lot dont.....
Also, Haas drives like an old grandma his world-class super and hypercars so that has a lot to do with it too. his "oil temps" are very VERY low... and CATERHAM has interesting theory about how even thin oils like Haas could be good on the track.
That said. MOST of the time, going as thin as you can is better. Exceptions would be: 1. "Problem" engines, 2. Engines that documentedly like thick HTHS oils (*cough* BMW M3* *cough* Porsche 997/anything.)*
He isnt a quack he is just richer than us all. Also, weird.
