The 950 was never a good snow tire but great other wise. All seasons are always a matter of trade offs and believe me, I've had worse in snow. I hope almost totaled means that you avoided all damage. First time out in new conditions can be daunting.
Quote:
I bought RE950 when they came out for my brand-new 2002 A4. Nice handling tire, but almost made me total my car in the first snow. Let me be clear, the a/s abilities of the Potenza RE950 were downright DANGEROUS. I'm soured from any Bridgestone purchases since.
Quote:
Quote:
Erm . . . no. You have misread the Tire Rack test. The "summer" tires you refer to (and which Tire Rack tested in the tests you cite to) are most definitely not 3-season tires. They fall into the category that Tire Rack calls "Extreme Performance Summer Tires" (different from Ultra High Performance or Maximum Performance). Here is Tire Rack's own definition of this specialized category:
Quote:
You want extreme dry street performance and are willing to trade some comfort and hydroplaning resistance to get it.
Not intended to be driven in snow or on ice, or at high speeds in deep standing water, these specially tuned tires combine big-block tread designs with aggressive tread compounds and reinforced internal constructions to emphasize dry road response, traction, handling and high speed capabilities for serious driving enthusiasts.
http://www.tirerack.com/tires/types/extremeperf.jsp
They have a sprinkler system to simulate wet conditions. They hardly flood the track such that hydroplaning becomes an issue.
Quote:
And aren't you the one who normally says hydroplaning shouldn't be an issue with modern crowned streets and highways?
Quote:
As a rule, tread design affects hydroplaning resistance at high speeds and in deep water. Tread compound affects wet traction at lower speeds or in shallow water.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=16
Quote:
Quote:
Quote:
GC4lunch is talking about generalities. Here we have actual testing results.
But in the bunch you refer to, there was not one single 3-season tire, your assertion to the contrary notwithstanding.
OK then. How about TR's other tests. A simple look at these tires in the "Ultra High Performance Summer" category shows that they have directional treads designed to evacuate water. Regardless - these pretty much are the "3-season tires" you speak about, not matter how they're marketed. Granted the conditions were likely different, but that only shows that those effects are more important than a simple distinction between -season/summer/all-season marketing strategy.
Ultra High Performance Summer (same car and tire size) on June 21, 2006:
http://www.tirerack.com/tires/tests/chartDisplay.jsp?ttid=78
Wet 50-0 MPH braking:
AVON Tech M500: 114.4 ft
BFGoodrich g-Force Sport: 133.9 ft
Dunlop Direzza DZ101: 140.9 ft
Fuzion ZRi: 106.6 ft
Quote:
The RE960AS isn't a world beater in dry conditions compared to other tires in its ultra high-performance A/S category. However - the one thing it does really well is wet traction. Bridgestone claims its tread design does a lot to improve wet weather traction, which is excellent. ... It was also adequate driving in Yosemite on Wawona Road and Glacier Point Road (to Badger Pass) on a couple of inches of snow.
Quote:
Now do I (or do you) really think that the BFG Killer Dry ("KD") tire stops 45% shorter (97.4 feet vs. 140.9 feet) on wet pavement than the Dunlop Direzza DZ101? No, I don't, and I am sure that you don't, either. Therefore, all the comparison shows is that the comparisons are valid only within groups of tires tested at the same time by the same test crew, and comparisons from one test to another test conducted by a different testing crew on a different date are impossible.
Quote:
An inherent quality of rubber compounds is to shed water. Build a tire from rubber compounds, and it will have a proclivity to shed water -- which is pretty much a Good Thing for wet braking, because it assists the tread to make more intimate contact with the pavement than it would if there was a layer of water between the tread and the pavement. However, that proclivity to shun water is a Bad Thing for snow traction: the tire does not like the snow, and will not stick to it, so when you press the accelerator, the tire spins. The solution for snow traction is to modify the tread compound so that it is not so hostile to water, so that snow will stick to the tread. Problem is, that modification necessarily compromises wet traction, for the very reasons stated at the beginning of this paragraph. As for what Bridgestone says about tread design, go back and review the relative importance of hydroplaning resistance to wet traction above.
Quote:
Now, I am not doubting or questioning that in your subjective evaluation of (probably not stressed) wet braking in uncontrolled conditions, it felt to you that the all-season tire "does really well" in wet conditions. I cannot tell you with any certainty whether I could tell in casual driving whether a tire that stops in 94.7 feet is braking any better than one that stops in 140.9 feet. The seat of my pants is a poor measuring instrument, and on a real road, with real objects I could slide into that I want to avoid, I will be modulating my brake pedal in response to visual inputs as well as to the feeling in the seat of my pants. But when I am making a purchasing decision as to tires, if I know that objective tests under controlled conditions have shown one tire will stop significantly shorter in an emergency on wet pavement than another, it is the shorter-stopping tire that I want under my car.
Quote:
Possibly. While it may be "killer dry", I would think the course is wet down similar to the DOT conditions used for the UTQG traction rating, and not even close to hydroplaning conditions.
Quote:
Unfortunately TR hasn't seen fit to do a test of tires in different categories on the same day.
Quote:
And siping is useful in increasing wet traction. Tread design does have an effect on wet traction, and the sipes used in all-season tires can compensate anywhere from a bit to a lot.
Quote:
At the very least, there was a test showing that the RE960AS did exceptionally well in wet braking, at least on one particular day.
Quote:
Really - you have no proof that the Bridgestone Potenza RE960AS Pole Position is an inferior wet braking/handling tire than many of the tires you would consider "3-season".
Quote:
o 2003 August 1: three "summer" tires, one "all season." All season finished fourth of four.
o 2004 May 28: three "summer" tires, one "all season." All season finished fourth of four.
o 2004 September 22: three "summer" tires, one "all season." All season finished fourth of four.
o 2004 October 14: three "summer" tires, one "all season." All season finished fourth of four.
o 2004 November 12: three "summer" tires, one "all season." All season finished fourth of four.
o 2005 April 15: three "summer" tires, one "all season." All season finished fourth of four.
o 2005 May 13: four "all season" tires. Interesting result: one specific tire model (Goodyear RS-A) that had finished dead last in one or more of the tests reported above when it was matched against "summer" tires finished -- by a comfortable margin -- first of the four tire models under test when the competition was against fellow "all season" tires.
o 2005 May 27: three "summer" tires, one "all season." All season finished fourth of four.
