Originally Posted By: oilnub
I can get Shell Helix Ultra 5w-40 but it's Group 3 nothing special.
Nothing special? The new GTL base stocks are actually pretty good. It has Noack of 7.1%, according to this report:
http://www.oil-club.ru/forum/topic/12199-shell-helix-ultra-5w-40-svezhee/
That actually looks very good especially considering the price. I'm not sure it will hold up for me but if I'm forced to do something extreme like 5K kms OCI's it could be something to keep up my sleeve.
Originally Posted By: drtyler
You do not want to run Amsoil SS 5W30 -- HTHS is 3.1 instead of 3.5 or greater. If you are considering Amsoil, look at their Euro offerings.
While I think the Pennzoil/Shell Euro 5W40, Castrol 0W30 or 0W40, or Mobil 1 0W40 would be fine, you could consider Red Line 5W30, 5W40, or 10W40. Most all of their oils have low NOACK and are durable under high temperatures.
oilnub said:440Magnum said:I think oil temps below 100C (212F)are more damaging these days than oil temps over 110-115C, given how stable modern oils are. I wouldn't worry at all about those oil temperatures at cruise- the benefits of keeping volatiles baked out of the oil far, FAR outweigh any potential oxidation concerns (which, for today's better oils, aren't really a concern until over 300F.
Leave it alone!
From the 335i thread, they reported the oils you mention didn't fare too well at all. Given that I am concerned about the oils I'll do a short stint on one of these oils we take as 'top tier' consumer oils then do a UOA. Hopefully my engine is not as bad as the 335i engines, although I fear it may be.
I do also plan to swap out the thermostat so as to decrease the cruise/normal oil temp to ~93*c from ~115*c to reduce the heat stress that was purported to contribute to the rapid breakdown in the 335i engines. I do realise not taking oil over 100*c will increase moisture content, and increase the higher boiling point volatiles in the oil, but at the same time I'd suggest volatiles with boiling points over 100*c aren't all that volatile. I've not had issues with oil before with cruise temps ~85-95*c so I'm happy to try it and see.
Originally Posted By: edyvw
Castrol 0W40 or M1 0W40. I know you do not need 0 oils, but still HTHS and NOACK of these oils is really good.
Indeed typically they are good, I've used m1 0w-40 in most of my previous vehicles but again, these don't seem to fair well in the N54. I'll use one of course, I have little choice in the matter, but will do a UOA shortly thereafter.
Originally Posted By: MCompact
Use BMW 5W-30 or M1 0W-40; either will work fine. Get a UOA at 2,000 and see what is going on.
Yes this or a similar oil will be my plan forward with a UOA to be done at low km after the change.
