Originally Posted By: Clevy
Originally Posted By: Cujet
Of course, the Ford Mustang of 1979 "might" qualify for this list.
This generation Mustang, when properly configured, with a good alignment and modern tires is still competitive today on the road course. They were quite capable.
Prior to that, the Mustang II, while not particularly "loved" by Americans or the press, actually had a good front end suspension design. One that's still used today in many kit cars. They could be made into capable racers without much fuss.
I've got an 82 Capri. 2.3l turbo I'm slowly starting to acquire parts for. Blow thru carb. The fox body platform was a decent handler and was very capable in the twisties.
I haven't decided yet whether to pull the 2.3 and run the tried and true Windsor small block. The cool factor with the turbo is nice but without modern engine controls I'm just not experienced enough with one to feel confident in tuning it.
A 5.0 though is common,parts are still cheap and easy to get.
It'll add front end weight though.
Decisions decisions.
I don't believe they were "blow through carbs". I think the carb was mounted above the turbo in a draw through setup, and the vacuum created by the setup caused oil ingestion. (However, I'm not 100% up on those Ford models, it's been a long time)
The better 2.3L setup is the SVO fuel injected setup, with 205HP in stock form. (T3-60 turbo) The parts are still very common (cheap) and they will easily make 275HP without much in the way of mods. 300+HP does require larger injectors, better cam and better intercooler.
I've run those 2.3L engines with well north of 30 pounds of boost. They will hold up well as long as the RPM is not allowed to get out of control. The connecting rods are the weak link.
