Well unless you purchased the extended waranty your is up. GM has a redesigned set of rings for the N.Star engine. For customers that complain of oil usuage 1 quart per 1000 is pretty normal for this maldesigned piston and ring setup. First the dealer is going to want to do a consumption test. They will fill it with dino oil and tell you to drive it as you normaly would. Then they are going to check it every 1000 miles. To see how much it uses. If it exceeds 1 qt. per 1000 miles they will replace your rings free of charge. Talk to your cadilac dealer about this. Your Area Service Manager might ok this without question as it is quite common. They will propably want to try top end cleaning first. You can probably cut they oil usuage by 60%-70% by switching to Redline.
