Hey guys, the car in question is a 2001 buick regal ls with around 87k, I dont think the fluid has ever been changed, everything with the transmission is fine, shifts are good. The fluid is also red in color, doenst look to be burnt.
I wanted to get the fluid changed with Amsoil synthetic fluid
http://www.amsoil.com/storefront/atf.aspx
Total capacity is 13qts, with drain n fill I will be replacing around 8 qts.
Is it ok to do a drain n fill with amsoil fluid? I do not have access to a T-TECH type machine
Thanks!
Thanks!
