I have heard a lot of talk about thicker oils lately and I have always been of the opinion that the grade called for should be used.
The only time I go against this rule is the 5w20 spec I usually use a 5w30 in the engines I own because it's usually just for CAFE standards and not really to the benefit of the engine.
But for an engine that calls for a 5w20 or 5w30 why use a 40 or 50 weight oil. What is the supposed benefit?
I just think that it creates a reduce flow situation through the engine by moving slower because it doesn't flow through the filter as well and because it's heavier to be pushed around.
Thoughts?
Thoughts?
