You use B12 chemtool as a flush not as an oil treatment you do not drive around with in your car. Try reading the back label it is approved for use as an Engine flush they just recomend 1/2 as much as I do which is fine if you do not have a high milage car with 100,000 miles of dino oil in it that you would like to remove. On top of that B12 has been use longer then any other solvent engine flush on the planet earth unless you caount adding a quart of kerosine as engine flush. B12 has been around since 1912 I think it is that is a long long time. On top of that I have used it on my car and I gurantee I get lower wear numbers on my UOA then you do and I do not even know what you drive how is that for big ones and confident. Are you a mechanic, lubrication engineer,tribologist, forensic engine tear down specialist or anything like that??? I am asking you Ionbeam just to be clear? Unlike some I do not just pull recommendations out of my rear I actualy base them on a combination of professional trial and error, trade school and college and my personal life. Last I checked not a lot of class actions suites against B12 Chemtool no FTC lawsuits for false advertising as they advertise it in the pint as an engine flush and fuel injector/carberator cleaner.
Did you know that many of those same solvents are in the production and extraction of oil from crude? Dino oil traditionally has solvents in it. PAO is made from reacted petrolem distilates and gas's. Crude is hit with solvents and extreme pressures and heat to get to the point that it can be used as motor oil. Ester's as found in cars motor oil and jet motor do not fail out of the sky ready made they use some harsh solvents,acids and alchols to react these things! The difference between something being harmful versus helpful is all in how you use it. Their is no hydrocarbon that is inherently evil!
Now because I was once a mechanic and used to do quality control and forensic powertrain tear down and trouble shot manufacturing machine ry problems as well I actually have a professional opinion. That opinion is actually based on real world observations. I am not sitting in my computer room thinking deep thoughts about oil! I have personnel used B12 Chemtool on not less then 100 car's not counting my own vechiles and my familys vechiles. I donot do this once a week. I have always held that things like solvent flush's should not be used more often then about 1 time per 75,000 miles if that. I generaly only do it once ever 100,000 miles. Sometimes I will soak the top of my pistons with the old Mola-soak but again I am guessing you have not heard of that before but it is in the archive I assure you and unlike your untested wild guess of an opinion about it possably disturbing the oil film it has been tried and tested hundrreds of times!
I do not talk math and would not got to a site about math because I am not an expert on math just because I passed my college math class's does not make me a Statician! So why it everyone with little or no experince feels free to make radical claims about stuff they know little about? So if you think B12 is going to disturb the oil film which is almost the funniest thing I have heard in a while jsut because of the way you state it then what do you think Amsoil FLush whose ingredients I copied fromt heir pdf and pasted her are going to do?
How much HTHS do you think an unloaded engine needs to fast idle sitting in the drive way for 15-30 minutes? Bear in mind that you add this to either your existing dirty fully formulated oil or you add it to fresh oil specifically for the flush.
Since Amsoil only in the last few years changed it's Engine Flush formula to one not so solvent heavy you would think that their would be thousands of cars sitting on the side of the road from those horrable Amsoil Engine Flush's. Where are they? It is easy to give an uneducated opinion about things you do not fully understand but why would you want to? Anything you add to your oil will change the state of the oils film strength, it flow be it laminar or not and it's AM/EP/AO properties. Just because you do not know what youa re doing does not mean it is not perfectly safe to do so it just means you should not do it. I always add that people should be cautious with solvent flush's because they are strong but not everyone is going to want to spend what Auto_rx cost. Not everyone has a paypal or a credit card and Auto-Rx is not available in stores!I pint of B12,SeaFoam
If their are two things I hate it is people that try to make other people make decisions based on fear especialy the "What if" variety of fear or the "it's Cheap Insurance" variety. My second most hated thing is people giving opinions when they do not have the personel or prefessional experince to back up their opinion! I stick to what I know and what I have personely used and tried a number of times! When I step into the unknown or am making an assumption based on passsed experinces I make sure to let the other person know that I am doing that and not representing my personel opinion as fact!
Every single Amsoil Sponsor on this site has used the flush at least once with a customer I would bet(making assumption) and probaly more then once! I doubt any of them have seen anything negative happen when it was used properly!Their are better then 10 different engine flush's on the market even the high end European oil companies like Motul have them! On the professional side every single oil c company seals a professional package for use either in the crankcase directly or for use with an engine flushing machine and they all make transmission flushing products as well for professionals.
HYDROTREATED PETROLEUM DISTILLATE, CAS# 64742
54
7, 15
20%
2
BUTOXYETHANOL, GLYCOL ETHER EB, CAS# 111
76
2, 20
25%
ALIPHATIC PETROLEUM DISTILLATES,
CAS# 64742
88
7, appx wt=60
65%
