This is my second UOA with this oil. My first result is here:
http://www.bobistheoilguy.com/forums/ubb...528#Post1405528
Couple of issues come up during this run. First was that for about 8,000 miles I had a faulty O2 sensor. Not that I'm lazy, just Autozone replacements were bad out of the box. Another issue that come up was that I had a coolant leak and replaced the radiator hose. Never overheated but was adding water and finally figured out the issue. The last issue is that my car developed a slight oil leak during this run. I topped it off with 1-1.5 quarts a few thousand miles before I changed the oil. I changed the oil when the level hit the min. mark and changed it because I was out of ACD and did not want to mix oils.
I am currently running M1 0w-30 AFE.
Let me know what you think!
[img:center]http://docs.google.com/fileview?id=0Bx_Z...lNjdjMzFk&hl=en[/img]
