Originally Posted By: Trav
Quote:
Aluminum is the right material for modern vehicles. Period,
Your comparing a Ford pick up to a modern tens of million dollar jet? Not realistic.
What grade of aluminum does the plane use? it is riveted and its shell has only 3 shapes cylindrical and flat or slightly curved.
How many times are aircraft inspected and corroded panels are found? A lot more than you would like us to believe. They corrode and corrode plenty!
https://www.faa.gov/regulations_policies...083-30_Ch06.pdf
The rivets are exposed and other than take off and landing in an area that use chemicals are not subjected to any sort of road salt.
They do use anti corrosion compounds in aircraft and the paint is Imron or other specialty paint. I buy Corban 22 for rustproofing, it is approved for aircraft wheel housings.
Imron was tried decades ago for car refinishing and found not only too costly but hazardous to health. look up Isocyanate.
The use of aluminum is a direct result of mandated fuel economy nothing more or less. Aluminum parts and removable panels is one thing but not the main structure of the car.
For a mass produced vehicle this is probably the worst material.
Airliners have been produced from 3003 aluminum. It's cheap, corrosion resistant, easy to form into compound curves and retains it's shape quite well. Sure, after 40 years, it corrodes. I'm sure the alloy chosen for automotive use will have similar properties.
As for aircraft not having compound curves, your kidding right? My Cessna Cardinal does not have a flat panel anywhere. Each fuselage panel contains a compound curve. And, many aircraft were produced with ZERO corrosion protection what-so-ever. They do operate in harsh conditions. You may forget that it's cold at altitude. Upon descent, that cold metal, in contact with warm, moist air, forms surface moisture over the entire surface. And, this happens on each flight. After 30 or 40 years of this, sure some corrosion forms.
Not to mention, many aircraft spend time flying the shoreline. Salt literally drips off aircraft located here in West Palm Beach, Florida. You are absolutely incorrect about the road salt being more severe.
