Over the weekend, I pulled the timing belt and one roller and tensioner to fix up a coolant leak at the thermostat housing (stupid Audi engineers). I've been this far in the engine several times, so I'm confident in my work.
Driving home from the office yesterday, I pulled off the highway and at the top of the off ramp it sounds like there's a large can of marbles under the hood. At this point, I'm only about a mile from home so I nurse it back to the garage and park it for the night. It was running normally, with no misfires detected. Not even a CEL, but it did not sound good. I'm thinking (hoping) that the serpentine belt tensioner has given up on life and is no longer holding tension, resulting in the noise I'm hearing.
I pulled the viscous fan and clutch and the serp belt and fired it up to see if the noise was gone. Nope, it's still just as loud and unnerving. Time to dig deeper.
Here is what I found:
OK, that's not a good start!
Ummm, that's melted plastic on the tensioning lever.
Something's definitely missing there.
I didn't get a pic of it, but the roller that places tension on the belt was no longer attached to the engine block and one of the washers was MIA. I'm certain that I tightened it when I put it back together after the coolant repair. With the new parts I'm putting back in, I will certainly be using a liberal amount of threadlock this time. I don't know how the thing still ran for that last mile, as the belt was very loose on the pass side camshaft sprocket and that bank was about 15 degrees out of time with the other side and crank.
And yes, I've purchased a couple of lottery tickets.
