Originally Posted By: kschachn
So if I use the product, how long can I drive under load with an empty oil pan?
Under load? Maybe to the edge of the road. Maybe 3 or 4 minutes, maybe more, maybe to the next off-ramp. There used to be a TV add for an additive product containing MoS2 wherein they drained the oil on camera, then drove the vehicle for 28 miles. So there! As I recall, the unlucky WWII airplane pilot got 3 or 4 minutes flying time - but that was enough time to land under power.
The devil is in the details. If you lose your oil, you lose a critical cooling function within the engine. Lubrication is not really the issue (and if you doubt that, simply consider an electric motor which has no pressure lubrication at all). If the weather is cool and you unload the engine and your cooling system is working well, you might make 20 miles. For the WWII pilot, the weather was always cool, his engine was low compression (about 6:1), his engine water cooling system was still working and the only power he needed was to power auxiliaries and make one final landing maneuver.
Subaru EJ engines (including the EJ255 in my vehicle) occasionally suffer from
oil pickup tube failure, said to result from brazing flux residue left on the part during manufacture. This is a known issue, but it mostly occurs outside the warranty period, so Subaru has been relatively indifferent to the problem. When the pickup tube cracks or breaks, the result is almost always catastrophic engine failure. MoS2 should prevent catastrophic engine failure if you shut the engine down promptly. You could also replace the oil pickup tube with an aftermarket part. You could also do both.
Nomex suits give race car drivers and helicopter pilots about
30 seconds of protection in a crash. MoS2 should give you 30 seconds of protection.
p.s. I had to drive out to Union City, Ohio this morning. When I left home, it was -4 degrees. When I rolled into Union City, it was -18 degrees. At that temperature, there's no telling how far I could have gone!
To the edge of the road? 30 seconds? I think you could do that with normal oil, don't you?
And end up with the same seized engine, right?
I don't think that I (or anyone else) can predict with certainty what the outcome will be. Which, incidentally, may be why oil companies don't want to go there. I do note that Liqui-Moly does mention limp-home protection in connection with their motor oil. I'm not sure how they define this. I would predict that you would be better off (and never worse off) under any situation, with MoS2 in your oil. That said, consider some possibilities:
- Situation 1: Suppose you cut the engine the instant you lose oil pressure. You could easily coast to the edge of the road or beyond with minimal internal engine damage. You could do this with or without MoS2 in the oil.
- Situation 2: If you had MoS2 in your oil (actually, attached inside your bearing journals), you could probably
drive to the edge of the road or maybe to the next crossover or exit with little chance of damage.
The key is engine heat. You no longer have flowing oil to dissipate the engine heat so your only option is to minimize that heat. Stay off the throttle, keep all possible load off the engine, keep your speed down. You could probably drive to the next off ramp, and maybe beyond. But just because you might be able to drive "28 miles," like the guy in the TV ad, is no reason to try it. Get to a shoulder or ramp and call a flatbed - probably a better (and safer) option than instantly cutting the engine.
Engines seize because of heat. Minimize the heat - reduce the chance of seizure. The molybdenum will continue to lubricate things quite well - even better than motor oil alone. The motor oil has probably drained out.
Here are a few other considerations:
- A low compression engine might survive this ordeal better than its high compression cousin - lighter bearing loading. And some engines have a much more robust big end (e.g. 5 main bearings instead of 3).
- The engine might survive but your turbo-charger might tank - the heat issue, again. The turbo is spinning at 100,000 rpm which probably doesn't help.
- What were you doing immediately before the pressure loss? Just cruising along? Climbing a three-mile 7% grade up Allegheny Mountain? You could probably survive either situation, but the survival odds are not equal.
Finally, your original question asked "...drive under load". Answer: the molybdenum doesn't care. It's an EP lubricant. It will stay in place and continue to provide lubrication, right up till the time your engine seizes from heat.
