The new ACEA Sequences are out
acea-oil-sequences-2021
Thanks to member BMWTurboDzl who first mentioned it.
Thanks, that makes sense.looks like they test 4 different elastomers... which will have different condemnmation limits
Those are the "light duty" sequences which cover petrol/gasoline and diesel use in light duty vehicles (as opposed to the E sequences for heavy duty diesel).Here is a more direct link to the petrol (gas) engine sequences
Some questions that come to mind:
What is up with Oil – Elastomer Compatibility ?
There are 3 full-SAPS oil types (A3/B4, A5/B5, A7/B7) but 4 tests (RE6, RE7, RE8, RE9). Do all 3 oils need to meet all 4 tests? Or just the 2 directly below them? Why not just one or two tests, are they that different or is it just the % limits?
Notice A3/B3 has been deleted as a spec.
Why only C4 has the Noack requirement of 11%, with everything else at 13% ? (Make them all 11%, or at least 12%).
Same with Valvetrain wear, why are some 27 and the others 33 ? (Make them all 27)
