Originally Posted By: semaj281
On that note, I found a handful of UOAs with Group III 5w-30 that still showed 10.3-10.8 cst after 6000 miles.
Of course, new-oil starting viscosity is also key in determining the used-oil viscosity, as there is a large range allowed by SAE. In addition, after the initial viscosity-index-improver-degradation-induced shear (happens after about first 1000 miles or less), the viscosity usually starts to slowly but uniformly increase again due to oxidation, sludge, etc.
You can usually tell if your viscosity is sufficient. If there is no excessive oil consumption, smoke, power loss, or fast oil degradation, your engine is probably doing OK and chances are that you don't need higher viscosities. A UOA can also be of added assurance.
