I have a friend who has a '99 Ford Escort who never change the oil. He did this because the salesman told him that the oil did not have to be changed for 60k mi while being informed of other long use items such as 100k use platinum-tipped spark plugs. He has maintained the oil level but now has an infrequent dashboard oil light. After he takes it to the dealer (who will probably change the oil and sending unit), what should he do to remove any build-up?
I suspect that everyone will recommend using Auto-RX and I agree. Is there anything else that can be done to loosen-up and remove some of the build-up before Auto-RX? Also, how often should the oil and/or filter be changed while the build-up is breaking down and suspended in the crankcase oil?
