Went to change oil in the wifes car today........went to CarQuest and picked up a Red filter. Get home and its a different size.
The engine has landings where the oil filter mounts for 2 different size filters....the one CQ speced, and one that cross refs to a Wix filter that does actually fit. Funny and fortunate thing about the other size is that its the same as my 2 other vehicles.
Filters in question:
Wix 51356 and Wix 51334
The Wix online catalog gives you the 51334 for the default, but if you look at the description for the 51356, it fits Acura 02-08. And when I pulled the filter off that was on there, its a Honda filter the same size as the 51356.
Two questions: should I switch to the larger filter? I didnt do the math to see if there is more surface area.
And.....any qualms about using the other set of "landing" where the bigger filter fits? It looks like the smaller filter has always been used, so the outer ring of the landing is a little bit dirty. Thats mostly why I didnt use the CQ filter at this time.
Thanks in advance.
-Chris
Thanks in advance.
-Chris
