Originally Posted By: cmorr
Originally Posted By: TechnoLoGs
It has a distributor. We used an old, ragged one when throwing engine back together.
You keep peeling off key information over hundreds of posts.
You need to sit down and outline all the steps that were done (what parts and from where)
Won't even ask why you chose to wait until the engine was installed to check plugs and wires from the "old ragged dist"
I'm stunned the thing even runs
I find some of these things a daunting task. I know I can get at 4 of the 6 spark plugs, if I was to check compression myself. I know the distributor, you basically have to lay on top of the engine to get to it and not drop screws, and my ribs are bruised. I have also been feeling sluggish this week and I am starting to suspect the car smelling like exhaust at lights is doing it.
I want to say this: Everyone is on point here. Today, in an effort to please the emissions, I did run hot water through brake booster, and changed the oil
as I read hat changing the oil before a test helps. This is when I discovered I now need a new screwdriver, as old one is lost. SO I need to change oil filter at a later time, as you take off air intake to get to it. I also stopped looking for the ALDL, which I maybe showed up somewhere in the dash I threw back together when I aligned my shifting, though i cant see a wire that it would be, and the hood cable poked my hand when i was doing this, and it made me bleed. Also, I was kneeling and my bruised ribs began to hurt when I did this.
I have been feeling woozy for days.
I am doing my best here and I asked to borrow Mom's car to go to work tomorrow so I wont feel woozy.
I also believe it is running rich, and all these tests suggested before I see about having the 0S sensor changed, if I cant get to the 02 sensor myself?
I am debating getting a new memory card and taking a pic of how my ALDL is absent. Light comes on "just after a surge of power," if that helps anything. It then turns itself off sitting at a light. And I cant find the ALDL.
I also see a lot less drips/leaks under it. I want to say "none" but I am sure I will see some when I say that.
And my engine oil pressure gauge never blinks when I Put 10W-40 in it.
