Originally Posted By: Garak
Originally Posted By: Kuato
All I stated before the landslide came down was that M1, in the 4.0 flat tappet Jeep engine, produced more than twice as much Fe in my samples compared to other oils, and made a recommendation against using it in flat tappet engines for that reason.
In fairness to you, it would only be natural to be alarmed by such results. It's just not the correct time to be alarmed.
From a hypothetical perspective, I'm sure inappropriate lubes could create some ugly UOAs, too. Running a 0w-20 in an off road diesel, for instance, might create an "interesting" UOA. I'm sure running 20w-50 with daily forced cold starts in -40 (i.e. with enough battery reserve to force the issue) could make for ugly UOAs, too.
I think we also have to draw the distinction between iron and other metals. Even the other metals leave a lot of room for guessing when one isn't sure about the additive package or the actual make up of bearings and things. Look what happens to certain numbers when you use an oil with a sodium based additive package or leaded race fuel.
And, if one thinks there is a problem with wear based on UOAs, there's only one way to tell, and that's to check the engine. I'm certainly not tearing into an engine just because a number is high on a few UOAs (unless it's something indicating coolant intrusion, but that's another matter). If I spin a bearing or the camshaft is so flat I have no power, then I'll worry about tearing into things.
As for actual wear, I don't think there will be huge differences between various oils, assuming they actually meet the specifications for the engine in question, and you're comparing apples to apples.
Thanks for that. All the oils tested were either 5w30 or 0w30 as spec'd for the vehicle. All other wear metals were within 1-2 ppm. Not alarmed, just not going to use M1 in this vehicle.
Now in all fairness, I got a great UOA in our Wrangler (2.4L four banger) with the same M1 0w30, so it works well in that engine.
