I might use M1 0w40 on that engine. It's hot viscosity is really only about halfway between a typical 30 and 40 grade.
If you have an oil pressure gauge, use that as a guideline.
It's "hot viscosity", unless it shears, is within the range for a 40 grade oil. That's why it is called 0w-40, not 0w-30.5
Never said the hot viscosity wasn't in spec, but it's well below typical.
Typical as compared to what, an HDEO? It isn't an HDEO, it is a Euro 40, and, not surprisingly, for that type of oil, its viscosity IS typical. PU 5w-40 is 13.2 @ 100 for example.
Quote:
The reason it's not called 35 is because no such spec officially exists.
And here I thought that I was making a joke
Quote:
If it did that label would give a more accurate impression of it.
More accurate compared to what? The entire grading system is a joke. Even if we had KV100 numbers listed instead of "grades", there's still HTHS, MRV, CCS....etc. The properties of a lubricant cannot be summarized with a single number. I think we can agree on this point, no?
Quote:
After refreshing my memory with some datasheets I see I was exaggerating about it being halfway between. It's closer to a typical 40 than a typical 30. But it's not a typical 40.
If one is concerned with the viscosity, they should look at the viscosity, not the vague classification it was assigned.
13.5cSt at 100C is lower than any other "40" I've seen a spec for.
Then you haven't been looking at the right "40" weight oils.
Here's PU 5w-40:
http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140007500286_20130123090_5.pdf
13.2 @ 100C
Castrol Edge 0w-40:
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4ABA633F17A143FD80257AA90053665B/$File/EDGE%20Professional%20European%20PDS_July_2012.pdf
13.5 @ 100C
Synpower 5w-40:
http://www.valvoline.com/pdf/synpower.pdf
13.5 @ 100C (HST)
13.1 @ 100C (MST)
Would you like some more examples?
