Id say pass. To much $$ for a vehicle thats been sitting too long. going to need work BEFORE you can drive it
Spot on. A cheap car just might be a very expensive proposition.My most expensive projects where ones that where "free" or too good of a deal
Yes, engine transverse on AWD. The extra differential was mounted below/behind the engine. It's a full time AWD system on that generation. No clutching in or out. Always engaged to all wheels, uses brakes to limit spin.Thanks everyone. I read about the oil cooler pipes. It is AWD but no trailer hitch so would it still have this cooler system?
Is the engine transverse mounted on AWD?
Good info....thanks.
By 09 the OP should be safe, but doesn't hurt to check.There is also another oil line for the rear bank VVT system. My 08 Highlander has a rubber hose between it and that could be a fail point. Also there was a recall in that I believe.
Thanks for the info. She will keep it a long time and take care of it. Her current Mercedes ML has over 280k and still runs good. Lots of little stuff starting to go bad. Temp control door etc. It's a 99.Yes, engine transverse on AWD. The extra differential was mounted below/behind the engine. It's a full time AWD system on that generation. No clutching in or out. Always engaged to all wheels, uses brakes to limit spin.
The "trailer prep package" on that era of toyotas was mostly cooling bits (bigger fan, bigger radiator, oil cooler, and second trans cooler) and a bigger alternator. It did not include hitch or wiring. Toyota's strategy was to sprinkle enough "tow prep" cars into the market that if a customer wanted to tow, the dealer could find one and add the hitch. The 2gr-fe oil cooler was impractical to add later due to the different upper oil pan.
Our 2009 Venza has been garage kept, and "low miles" for being 15 years old at 90k. Despite the downers in this thread, our rubber bits and trim are in great shape. I have no concerns about parts availability for a 2009 toyota within the next 10 years. I don't know that I'd give $13k for one, but it could be a very respectable automobile, expecially if your daughter plans to put a bunch of miles on it. Granted, the 2009 venza is a generation newer than a 2009 RX or Highlander would be.
Beautiful long lasting purchase!
Yes, this is something you want to look into. There is a recall on the steering columns for certain RX models.Steering column clunk.
Recommended, not required. I think you lose about 5hp IIRC running 87.Doesn't that engine spec high octane gas?...not sure how they do on the lower octane stuff. I believe they modified them to run 87 in 2012/13.
CO vehicle has its advantages due to dry climate. But, some challenges. I would replace all coolant hoses and serpentine belt. Luckily car was garaged as sun is unforgiving here.Well she bought it and drove it back east from Denver. Turns out it had 21k on it. It’s loaded. I haven’t seen it yet but will check it out and look for these items. Thanks everyone.
