Brand new owner of a 99 CBR F4 with 45km (not miles) that had been sitting for the last 3 years. Gas had all but evaporated.
It was running but very rough and would die out after a min of idling so I decided to clean the carbs and change the spark plugs.
I was very careful with the carbs and did only one bowl at a time, the float pin & seat were in excellent shape. The needle jet was rusty/tarnished and I took care to gently polish before replacing. The floats was tested in a bowl of gasoline and were measured for proper height. Floats are non-adjustable and no modifications were made to the carbs.
Now when I try and start it, the engine completely floods, gas in spark plug wells, gas in cylinder head, won't fire at all unless I turn the gas line to off at which point it will run until the gas runs dry.
At the moment the plugs are out and drying, battery charger is hooked up & the gas soaked oil has been changed. I just don't get it, the floats are perfect, i even tried installing a shim in the floats so they would choke the gas off earlier, the float needles are spotless, its an oem fuel pump so there is no change in fuel pressure. I'm at a loss as to my next step. Why would it not flood before the carb cleaning and start to flood after cleaning?
