2009 Silverado GM 5.3L PYB 5w30 SN
What about the HIGH LEAD?? This was my 4th run with PYB (2nd run with PYB/SN). OLM still showed 62% remaining and I had wanted to extend oil change out to at least 5-6K. Current fill is PP 5w30 SM. All suggestions/comments welcome.
BLACKSTONE COMMENTS:
Wear for the most part looks good in the second sample from your Silverado. Copper dropped to average and with the exception of lead, all metals read around universal averages (based on 5,800 miles). Lead tends to show bearing wear and at 24ppm, it's a lot higher than we like to see. Nothing obvious turned up to explain the increase. The viscosity read a little low for 5W30, but no fuel or other harmful contaminaiton was present. We suggest sticking with 3,000 for now; we'll look for lead to improve next time.
Code:
OIL PYB5w30 CasGTX5w30
MI on OIL 2956 3135
MI on UNIT 19999 4843
Sample Date 2/20/2011 5/7/2010
ALUMINUM 3 4
CHROMIUM 1 1
IRON 9 19
COPPER 40 190
LEAD 24 10
TIN 3 3
MOLYBDENUM 246 5
NICKEL 1 1
MANGANESE 1 6
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 3
BORON 69 4
SILICON 12 23
SODIUM 5 269
CALCIUM 2267 2139
MAGNESIUM 7 7
PHOSPHOURS 717 675
ZINC 779 863
BARIUM 0 0
SUS VIS 210F 54.3 55.8
cSt @ 100C 8.58 9.00
FLASHPOINT F 375 400
Fuel 0.0 0.0
Antifreeze 0.0 0.0
Water 0.0 0.0
Insolubles 0.2 0.3
TBN 4.3
Code:
MI on OIL 2956 3135
ALUMINUM 3 4
CHROMIUM 1 1
IRON 9 19
COPPER 40 190
LEAD 24 10
TIN 3 3
MOLYBDENUM 246 5
NICKEL 1 1
MANGANESE 1 6
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 3
BORON 69 4
SILICON 12 23
SODIUM 5 269
CALCIUM 2267 2139
MAGNESIUM 7 7
PHOSPHOURS 717 675
ZINC 779 863
BARIUM 0 0
Fuel 0.0 0.0
Antifreeze 0.0 0.0
Water 0.0 0.0
Insolubles 0.2 0.3
TBN 4.3
