Home
[cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax
Posted By: wwillson
[cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/06/18 09:05 PM
This filter is from my 2018 Duramax. This is the original spin-on filter with a total of 8,000 miles. There is a small amount of metal flakes in the filter and only enough clutch friction material to discolor the media. I see no reason to change this filter more often than 25,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple grams.
Posted By: Zee09
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/06/18 09:25 PM
Yeah looks like a long term filter.
Posted By: DoubleWasp
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/06/18 11:49 PM
My understanding is that most transmission spin-on filters by the OEM are still rock catchers. Better rock catchers than the pan filters, but still around 60-80 microns. That's why I replaced mine with an XG7317.
Posted By: bobbobtar
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/07/18 02:10 AM
When I had a 2009 Chevy Duramax with the Allison 1000 transmission I would change the trans. filer every oil change about 10,000 miles cheap insurance.
Posted By: Linctex
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/07/18 04:34 AM
Originally Posted by wwillson
I see no reason to change this filter more often than 25,000 50,000-75,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple milligrams grams
There, I fixed all of that for you.
Posted By: BlakeB
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/10/18 08:22 PM
I changed the spin-on trans filter on my Dads 2016 LML at 31k with 2073 hours. The magnet had some fuzz on it, but nothing excessive. I haven’t cut the filter open yet, but if I do I’ll post pics.
I checked on Allison’s site and this is what the fluid and filter calculator gave me:
Posted By: wwillson
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/11/18 01:28 AM
Allison calculator here: https://www.allisontransmission.com/parts-service/fluid-filter-calculator
Posted By: BlakeB
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/11/18 01:33 AM
How many hours on your L5P?
Posted By: wwillson
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/11/18 01:35 AM
190 hrs
Posted By: dave1251
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax - 10/20/18 03:33 AM
And yet what is percentage of failed transmissions? Not very high.
© 2019 Bob Is The Oil Guy
