So just had an issue pop up in the truck. Need to tow with it RIGHT NOW and can't get the trailer lights working. I don't want to , but I am close to just tapping into the tail lights to get it working ASAP.
It *did* work the last time I used it. It does not work now.
I have verified that the ground on both the 7 pin and the 4 pin are good. I am not getting power to either or the connector up in the frame. Also checked fuse 13 under the steering column and that is good.
Is there anywhere else I should be looking?
This is a 2001 F350 5.4 XL
