Home
Oil question for a 2018 6.7 Powerstroke
Posted By: Dfinkler
Oil question for a 2018 6.7 Powerstroke - 06/13/18 03:05 PM
My mechanic is telling that he wants me to use schaeffer 15w/40. What do you recommend for a 2018 F250 Powerstroke? I live in southern Wisconsin.
Posted By: JohnnyJohnson
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 03:09 PM
Yah I'll bet he does what's he going to charge you for it?
Posted By: BrocLuno
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 03:17 PM
Schaefers is good oil. Mail order it and carry it in. See what he says when you supply the oil laugh
Posted By: Cedarshark
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 03:21 PM
Difficult to answer unless you provide more info. We know you need cold starting capability. How much do you drive and tow?
Posted By: umungus1122
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 04:26 PM
What does it spec? Do you have an auxiliary oil cooler? How much do you tow?
Posted By: Donald
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 04:28 PM
I would run a 5W40 synthetic that is Ford approved. You will need to check the Ford document on oils approved for the Ford Powerstroke (this is all about CK-4 oil).
Rotella T6 5W40 in the containers that pass the Ford spec would good.
Delo 5W40 is also good. I see a lot of that oil that is CJ-4 on shelves at Walmart. Stock up on some of that. The CJ-4 passes the Ford spec. But if its CK-4 then you need to check to see if it passes the Ford spec.
Posted By: Danno
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 04:48 PM
Yes, make sure it has the Ford spec WSS-M2C171-F1, a lot of CK-4 oils do not meet the Ford spec.
Given you are in Wisconsin, I would look at a 5W-40 weight.
https://www.fcsdchemicalsandlubricants.c...20Statement.pdf
https://www.fcsdchemicalsandlubricants.com/main/additionalinfo/dieseloilsWSSM2C171F1.pdf
Posted By: CT8
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 05:56 PM
Read the owners manual and use an oil with the specs recommended by Ford.Buy an oil from any of the major companies.
Posted By: Zee09
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 07:58 PM
You really don't need your mechanic to change your oil.
That said I just got out from under my SUV now and changed it so I
understand.......
Ford gives big deal coupons on new trucks and you couldn't even buy the oil for what they do it for. They used to take 13.5 quarts. Don't know what your new one takes.
But an oil change from an independent could be really expensive.
Posted By: Langanobob
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 08:41 PM
I suggest asking Schaeffers and getting their recommendation. We need to be kind to Schaeffers around here, the Bob (RIP) in Bobistheoilguy was a Schaeffers rep.
Posted By: Buzzinhalfdozen
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 09:56 PM
Unless you use the truck for towing and by towing I mean more than on the weekends you don't need a 15w-40 or 5w-40. If you look at previous threads there are plenty of powerstrokes running a 10w-30. 10w-30 as far as I know is factory fill. I've read alot of threads where 5w-40 shears down to a 30 anyway while the 10w-30 stays in grade. No need for expensive synthetics if you're going to change oil according to the owners manual and not push gvwr.
My dad just picked up a new 2018 F-250 I put Rotella T5 10w-30 in it for him at 4400 miles. He tows 15k on the weekends. Will be keeping a UOA record on this truck as well. By the way there are quite a few c&p of filters as well, take a look. I know the baldwin b7379 filter is wire backed synthetic as that's what I put on.
Posted By: Zee09
Re: Oil question for a 2018 6.7 Powerstroke - 06/13/18 10:31 PM
Did he wait the 1000 miles before he towed?
That was tough on me, the wait smile
Re: Oil question for a 2018 6.7 Powerstroke - 06/14/18 12:46 AM
Yes he did, I think a vacation was taken shortly after purchase and that was about 1500 miles.
Posted By: BoiseRob
Re: Oil question for a 2018 6.7 Powerstroke - 06/14/18 12:33 PM
Schaeffer's Supreme 9000 series is still CJ4. My Jeep GC Ecodiesel uses the S-9000 5w40 and my LBZ Duramax uses the S-9012 10w30. Great oil at a reasonable price...
FYI... The Duramax pulls our 10K# TT throughout the Idaho Rockies..
Posted By: beanoil
Re: Oil question for a 2018 6.7 Powerstroke - 06/14/18 02:43 PM
2016 PSD owner here.
Schaeffer is a fine oil no doubt. So is Valvoline Premium Blue and Rotella. All of those vendors 10w30 are on the list.
I'm in the camp of a 10 w being good to 20 degrees F, so if you get colder than that in Wisconsin, consider a 5w40. Your truck going to a cold climate may have come with a block heater. If so, I would stick with the 10w30 year round. Seriously, you'll find the 6.7 will start and run in any temperature you are brave enough to walk out into unassisted anyway.
I'm running Delo 15w30 in mine, but it gets stored along with the camper from October through March, so no cold starts for me.
Posted By: Shata
Re: Oil question for a 2018 6.7 Powerstroke - 06/14/18 07:18 PM
Im pretty sure Delo meets the ford spec. I use 15w-40 delo sde in my Duramax. Good stuff. I would be more concerned about bypass filter on your diesel.
Posted By: claluja
Re: Oil question for a 2018 6.7 Powerstroke - 06/15/18 02:05 AM
OP - the Schaeffer 15w40 synthetic blend your mechanic is recommending is on Ford's approved list, and is a good oil.
Only caveat is that I wouldn't use a 15w below about 10 degrees F without a block heater. Been there done that - not good.
Posted By: beanoil
Re: Oil question for a 2018 6.7 Powerstroke - 06/15/18 01:24 PM
Delo is not on the list. At least not the new CK-4 stuff. There is still CJ-4 in the wild, that is OK.
Bypass filter? None from the factory obviously, but IMO, any diesel benefits from bypass filtration especially if extending OCI, and leaving emissions stuff intact. Lots of options for the 6.7 platform.
Posted By: F250_SUPER_4x4
Re: Oil question for a 2018 6.7 Powerstroke - 06/22/18 05:09 PM
Chevron decided to not make any CK4 only oils, all of their oils are CK4/SN multi vehicle so a no go for FORD PSDs.
Posted By: TiredTrucker
Re: Oil question for a 2018 6.7 Powerstroke - 07/23/18 10:42 AM
I have grown pretty fond of Schaeffer's 711 10w30 CK-4 in my factory reman Detroit 60. It stays tighter in grade than 15w40 Schaeffer it got early on does. I use it year round in a Class 8 that moves an average 65,000 lb of truck and cargo. 858,000 miles on the motor since the reman. Still only uses about 2 qt in 22,550 mile average oil changes as it has all of it's life and UOA's look as good as when it had 50,000 miles on the reman. As soon as Schaeffer started switching to CK-4 I started using the stuff.
Posted By: Garak
Re: Oil question for a 2018 6.7 Powerstroke - 07/23/18 10:40 PM
One could still formulate a CK-4 only HDEO and still not be on Ford's list. The SN doesn't matter with 40 grades, and Mobil hasn't bothered certifying anything for Ford's latest list except their most basic bulk oil. Oh, and low phosphorus Delvac 1 LE 5w-30 is on their "E" iteration of the list. whistle
Posted By: CarllT100
Re: Oil question for a 2018 6.7 Powerstroke - 08/06/18 05:32 PM
Thank you for this info and the links. Cheers1
Posted By: dnewton3
Re: Oil question for a 2018 6.7 Powerstroke - 08/06/18 06:54 PM
Oddly, there are some Ford approved lubes on their list that do not have the (purportedly needed) 1000ppm of Phos; we've seen some UOAs where the phos was lower than the Ford imposed 1000ppm.
Typical schizophrenic Ford speak ... Go figure.
You cannot really go wrong by using a Ford approved lube. But I personally am not convinced that Ford's requirement of phos is nearly as important as they imply.
© 2019 Bob Is The Oil Guy
