Originally Posted By: dslofti
I have a accord that calls for 5w20, it has bout 175k on it. I see no leaks or oil weeping around, I just it bout 2500 miles ago with mobil 1 5w20. It is now almost down to the add bar on the dip stick. I thought bout trying mobil 1 high milege but I don't want my seals to start leaking. Or maybe just go to mobil super 5000 see if that helps. What do you guys think?
How much oil is it burning ??
Changing to an HM oil will not start an oil leak.
If you are concerned out the oil consumption rate, first of all make sure the CCV (Crank Case Vent) is not blocked. Then I would move up a grade to an 0 or 5w30 and either switch to a major brand (Mobil are good) HM oil, or if the problem is serious, try a can of stop leak additive. If you do decide to use an oil additive, use one made by a real good engine oil company, like Liqui Moly, not some back street snake oil mixers.
