You can handle the FL400S/FL910 filter. Your basic filter ...almost industry wide uses a 2.8/2.4 (+/-) gasket ...and that's about everything ..hydraulics included (some). Yes, there are larger gaskets ..surely so ..but then you're typically out of the automotive lines.
Older Nissan
Part Number: 51521
UPC Number: 765809515215
Principal Application: Alfa-Romeo (86-93), Nissan Cars (67-89), Porsche (70-76), VW (71-83), Case, David Brown, Ford, New Holland Tractors, Nissan, Toyota Forklifts
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.790
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Toyota
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-07), Various GM, Saturn (85-07), Lexus (90-07), Saab (67-07), Suzuki (86-02), Toyota (88-07), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Thread Size: 3/4-16
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Gasket Diameters
Attached 2.734 2.430 0.226
Small gasket Toyota
Part Number: 51394
UPC Number: 765809513945
Principal Application: GM (85-05), Daihatsu (88-92), Infiniti (91-96), Kawasaki Mules, Nissan (91-95), Toyota (80-07), Scion (04-07), Atlas-Copco, Briggs&Stratton, Cub Cadet, Generac, John Deere, Kubota, New Holland
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.977
Outer Diameter Top: 2.685
Thread Size: 3/4-16
Burst Pressure-PSI: 400
Gasket Diameters
Attached 2.475 2.173 0.233
FL910/FL400
Part Number: 51215
UPC Number: 765809512153
Principal Application: Harley-Davidson Motorcycles, Ford, Mazda (03-07) (For chrome version, use 51225)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
Nominal Micron Rating: 24
Gasket Diameters
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Mercury (81-07), Chrysler/Jeep (02-07), Mazda Trucks (94-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Beta Ratio: 2/20=14/31
Nominal Micron Rating: 20
Gasket Diameters
The FL1A/FL300
zoom
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Gasket Diameters
Attached (3614) 2.734 2.430 0.226
Not worth worrying about. I'm using one of these right now on my wife's 4.0. It's an EaO57 dinky thing.
