Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Helicopter
by Exhaustgases - 01/28/20 01:25 AM
Shell Helix Ultra 5W-30
by SR5 - 01/28/20 12:30 AM
Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Towkid, denor, Jubaxtreme, CAJ1966, Shiza
70550 Registered Users
110 registered members (01rangerxl, 2oldtommy, 2015_PSD, ARCOgraphite, 2011335d, 2010Civic, 10 invisible), 3,134 guests, and 17 spiders.
Topics300,675
Posts5,180,910
Members70,550
Delo 400 15w40, 1000miles on it, 1968 chevelle. #782012 12/04/06 06:59 PM
L
lucky3 Offline OP
L
Here's what my oil test said. Its a 355 in a 68 chevelle, its driven pretty hard most of the time.
iron 58
chromium 4
lead 37
copper 12
tin 0
aluminum 9
nickel 0
silicon 49
boron 19
sodium 154
magnesium 18
calcium 2967
barium 0
phosphorus 1260
zinc 1502
moly 83
titanium 0
vanadium 0
potassium 210
I know i have a coolent problem, i'm taking the intake and heads off to replace the gaskets. My main concern was i thought i had a cam going bad and it looks like it isn't what i can read from the test. This is my first oil test done. I would really like to find out what the average numbers are for each one.
thanks,
Re: Delo 400 15w40, 1000miles on it, 1968 chevelle. [Re: lucky3] #782013 12/04/06 08:11 PM
B
benjamming Offline
B
Is the 1000 miles the distance on the oil, engine, or both? When was the last rebuild?
What lab did the analysis?
Does it get cold where you are?
Re: Delo 400 15w40, 1000miles on it, 1968 chevelle. [Re: benjamming] #782014 12/04/06 08:56 PM
L
lucky3 Offline OP
L
I was rebuilt about 6yrs ago, it has probly 8000miles on it. I don't run it when its cold out. 1000miles was on the oil and filter. I sent it in through napa's carrier.
Re: Delo 400 15w40, 1000miles on it, 1968 chevelle. [Re: lucky3] #782015 12/04/06 09:11 PM
daman Offline
isn't that iron and lead a little high????
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Delo 400 15w40, 1000miles on it, 1968 chevelle. [Re: daman] #782016 12/05/06 02:23 AM
A
AndyH Offline
A
Silicon seems pretty elevated as well. What kind of air filter are you using?
'19 VW Golf R: OEM Factory Fill
'19 VW Alltrack: OEM Factory Fill
'18 Audi S3: Mobil 1 0W-40
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: AndyH] #782017 12/05/06 02:56 AM
Drew99GT Offline
You have a major internal coolent leak. Rip it all down, install new intake and head gaskets, seal the front/back of the intake with a healthy bead of RTV and git r done right! That's all I can say.
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: Drew99GT] #782018 12/08/06 05:15 AM
DJ Offline
Good to see this made it here. I think the low feed back is due to the fact the coolant and dirt are so obvious and severe they need to be addressed before anything else can be evaluated.
96 Caprice 165K well modified
95 Roadmaster Wagon 190K and basically stock
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: DJ] #782019 12/10/06 04:08 AM
L
lucky3 Offline OP
L
I'm using a k&n air filter
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: lucky3] #782020 12/10/06 04:22 AM
L
LargeCarManX2 Offline
L
Average numbers in general range are:
Iron 5-25 Chrom 5-20 Lead 30 Copper 5-30 Tin 20 Alum 5-20 Silicon 20 Sodium 20
The camshaft would be iron in excessive numbers above 500.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: lucky3] #782021 12/13/06 01:50 AM
T
Thermo1223 Offline
T
Just trash it and get a regular paper one...not worth the damage it will due.
2016 VW Tiguan
2013 Ford Fiesta
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: Thermo1223] #782022 12/13/06 02:28 AM
L
L
Thermo, his silicon is in the normal range?
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: LargeCarManX2] #782023 12/13/06 08:22 AM
J
JohnBrowning Offline
J
LargeCarManX2 his silicone is not anywhere near normal! Anything higher then about 23ppm's will always get flagged around here unless the oil you are useing use's a lot of silicone an an antifoam agent. Most UOA on vechiles with a properly functioning OEM paper airfilter are in the 8-20 ppm range if the milage is 7500 or less ont he OCI. If they go past about 7500 miles then it is usualy in the 15- low 20's. His iron and lead are also sky high but those are proably a combination of high silicone and coolant leak. Once he fix's the coolant leak we will be able to get a better look at his filtration and wear numbers.
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: JohnBrowning] #782024 12/13/06 03:34 PM
L
L
Whoops..........I had 20 on my mind and his was 49. Correcto, and thanks for bringing that to my attention
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: Thermo1223] #2364903 09/02/11 05:44 AM
M
Merkava_4 Offline
M
I agree, but save the K&N for the track. Those K&N air filters let in a lot of dirty air.
Re: Delo 400 15w40, 1000miles on it, 1968 chevel [Re: lucky3] #2365107 09/02/11 10:06 AM
R
Rob_Roy Offline
R
Wear metals will go nuts with coolant in the oil. Get the coolant leak fixed, give the car one or two short oil changes to get the residual coolant out, and then refill with an oil of your choice. I think your current choice of 15w40 is fine, but you need to let things settle down before you try another UOA.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
