****-- this doesn't make sense. If the FF filter filters down to, typically, 10 microns for a good one, and the bypass filters down to a microon-- then what in the world is there for the fullflow to filter out?
Given the above-- if the bypass is supposedly good for upwards of 100k miles [not what I was told by two actual Amsoil reps, BTW], then how is it the FF filter must be changed every year or so, when there's nothing in the oil big enough for it to catch?
Also-- "filtration is absolute 3 microns, and 1 micron in repeat runs" Given that filtration is a function of the porosity of a filter, how is the filtration media going to catch something smaller just because it's come round for a 5th pass at the material? Granted filters filter better near the end of their service life due to blockage of the pores- but at that time it's time for a filter change, perhaps even past time.
Regardless-- 0.5 microns, first pass, beats 3 or even 1 micron first or 15th pass, every time. If the logic regarding the multiple-passes-means-it-filters-better bit is accurate, then surely the Motorguard must filter down to 0.15 microns after a few passes?
