I would appreciate help finding detailed specifications about the Motorcraft FL836.
1. Does it have a base-end bypass valve like most larger Motorcraft filters? If so, does this greatly reduce the filtration area in this small filter?
2. What are the bypass specifications?
3. Does it have an ADBV, and if so, what is it made of?
Finally, how does the performance of this filter compare to Bosch Premium 3311 or Purolator PureONE PL14476?
