2019 Subaru Crosstrek:
I used the CRC Intake Valve and Turbo Cleaner. A short piece of 3/8" tygon hose. Drilled a small hole through the cork and stuck it in the tubing. You want to use a short hose so it stays atomized.
Heated up the vehicle and using 1 or 2 second bursts while the wife kept it at around 2K rpm. Took about 15 Minutes+ to use the can. Serious smoke out the back. Directions are on the can.
When I was done I drove it hard. No smoke. Oh yea..it gave Two codes: Bank 1 and Bank 2 Fuel Rich. Cleared them
