93K mile GM 5.3 6.2 Carbon Cleaning Intake Valves...(from 4/28/20)
wemay
Site Donor 2023
Everglades
NOT a GM ISSUE - this is a function of Direct injection and affects vehicles in varying degrees of severity.
you can find one of these videos on virtually every make that uses direct injection.
Forget cleaning the heads i will just upgrade to ported heads when the time comes.
Is he implying that the car was driven easy therefore has more buildup? Sounds that way. Very beginning of video.
Yeah, I got that too. I've seen so many of these that it's hit or miss as to level of build up and if it causes drivability issues or not. No hard fast rule.
I wouldnt let these guys get within 100 feet of my truck! All the crud that they brake loose but dont recover goes into the cylinder. Not ideal.
Originally Posted by dave1251
Wemay. Thank you for posting.
ðŸ‘
