Forums Migration
Please read this thread
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Purolator Boss
by RazorsEdge - 07/08/20 02:01 PM
B2300 frame repair.
by simple_gifts - 07/08/20 01:48 PM
O2 sensor adapter with "mini catalytic converter"
by keantoken - 07/08/20 01:48 PM
Peeled veneer paint on vintage Pioneer
by Alfred_B - 07/08/20 01:40 PM
Shift Solenoids Cleaner additive?
by Husam - 07/08/20 01:11 PM
D rings for towing
by cknight49090 - 07/08/20 01:06 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
111 registered members (5AcresAndAFool, 2010Civic, 4WD, 55hambone, 66ROGUE, 2009Edge, 11 invisible), 1,776 guests, and 29 spiders.
Topics307,620
Posts5,314,376
Members71,888
WSS-M2C200-D vs -D2 vs D3 #5440779 05/28/20 09:41 AM
M
mossietheno1 Offline OP
M
Hi all
The Main point is that I'm trying to understand are WSS-M2C200-D vs WSS-M2C200-D2 and WSS-M2C200-D3 are backwards compataible?
Just trying to figure gearbox oil for B76M-R which seems to be a ford-Mazda gearbox.
Castrol recommends a 75W which is WSS-M2C200-D2 I'm wondering would it be better if i went with a WSS-M2C200-D3 oil.
Thanks
Corolla 4zz-fe [1] 6 Month OCI Will do
Corolla 1nd-tv [1] Moving to better
530D M57D30TÜ [1] Will do
107 1kr-fe [1] Moving to better
Mazda 3 Diesel DV6C, New to me
[1]Castrol C3 5W-30
Re: WSS-M2C200-D vs -D2 vs D3 [Re: mossietheno1] #5441098 05/28/20 04:01 PM
M
M
found these sheets from ford.[1],[2]
seem to answer that WSS-M2C200-D is an older version of WSS-M2C200-D2 but WSS-M2C200-D3 totally different.
This website go along the same though process.
WSS-M2C200-D [3]
WSS-M2C200-D2 [4]
WSS-M2C200-D3 [5]
[1]https://www.msds.ford.com/cpc/productDetails.asp?pgn=8&FIRNo=181193
[2]https://www.msds.ford.com/cpc/productDetails.asp?pgn=8&FIRNo=189486
[3]https://standards.globalspec.com/std/1101206/ford-wss-m2c200-d
[4]https://standards.globalspec.com/std/1243554/FORD%20WSS-M2C200-D2
[5]https://standards.globalspec.com/std/1601847/FORD%20WSS-M2C200-D3
[1]Castrol C3 5W-30
Re: WSS-M2C200-D vs -D2 vs D3 [Re: mossietheno1] #5441141 05/28/20 04:58 PM
P
pbm Offline
P
I believe Castrol Syntran meets that D2 spec....so does Volvo's MTF for the MTX-75.
'Journalism is Dead'
Re: WSS-M2C200-D vs -D2 vs D3 [Re: mossietheno1] #5467790 07/02/20 11:03 AM
M
M
Thanks pbm, I will put castrol on the list for the comparative gearbox oils before I buy.
[1]Castrol C3 5W-30
