- Joined
- Apr 13, 2013
- Messages
- 3,221
Toilet wasn't flushing correctly; turned out the old fill valve was leaking water out the top. Bought the same replacement part (Flushmaster 400A) and set the height & water fill level correctly as listed in the instructions.
Toilet flushes great again but now once a day, it makes a running noise for like 2 seconds. Doesn't phantom flush but just a running noise. The old busted part never did this. I ruled out a possible bad flapper by adding some food coloring to the tank water; the bowl stayed clean,
Is the new fill valve bad out-of-the-box?
