Originally Posted by painfx
From the internet - PEA additives cleans the most efficient and does not leave behind residue/deposits. This is why it is the best. There is a reason why people want to buy fuel system cleaners with high PEA% amount. I am sure you guys know about the greats about PEA additives.
According to wikipedia, Chevron was the first to introduce PEA additives to their gasoline.
If PEA additive is not the best, what other additive is better than PEA that can clean deposits efficiently and not leave behind residue?
I am not claiming to be an expert. I am also here to learn.
From reading the information on most forums, PEA additive is what people want.
@ y_p_w, you stated PEA is not being used as a detergent. Can you explain?
The primary chemical uses of PEA are for curing plastics and paints. It's a broad category that includes a lot of chemicals that won't be useful as fuel detergents.
Some of the literature on PEA use indicates that some types are in fuel additives for uses other than as a detergent.
And there are certainly PEAs used in additives other than from Chevron. This is from Afton, although it's marketed as an aftermarket fuel treatment and not specifically for pump fuel.
Quote
https://www.aftonchemical.com/SBU/Fuels/Diesel/Sub/Gasoline/HiTEC-6406
Application
HiTEC® 6406 gasoline performance additive is specifically formulated for use as an aftermarket fuel treatment additive to control combustion chamber deposits with exceptional control of fuel injector, PFI, DIG, and intake valve deposits. HiTEC® 6406 is formulated with Afton Chemical's high purity polyetheramine detergent and is compatible in high ethanol fuels.
As for the use of PEA in detergents, here's just one patent by Lubrizol that mentions the use of PEA detergents.
https://patents.google.com/patent/US20110162260
What I'm trying to get across might be summed up by the adage "There's more than one way to skin a cat." PEA is very good as a detergent, but I'd worry far more about how well an overall additive package works. There's no particular reason why a detergent additive package has to include PEA to achieve maximum effectiveness. Like many things, it might be possible to simply use more of something else to be equally effective.
