Ravenol ATF Equivalent for Mazda Type-FZ
CA
Straight from the page you linked they state:
Originally Posted by Ravenol
Schmierstoffvertrieb GmbH does not liable for transmission failures in case of
wrong selection of RAVENOL special transmission fluid.
If they can't even get the verbiage right in their disclaimer statement, why would you trust the product?
Now, beyond that, you state that the OEM fluid is nearly the same price.
Why would you mess with this unlicensed stuff???
It just makes no sense.
Ravenol is a botique oil like Amsoil, it tends to be good stuff, I'm pretty sure that disclaimer isn't that they aren't liable if you use their FZ equivalent in a transmission that calls for it, I'm sure they mean that they don't take liability if you use the wrong type of fluid in your transmission ie. if you put Ravenol Type FZ in your CVT or something like that.
I have used this in my CX-5, did 3 drain and refills, shifts are great and the Ravenol is a full synthetic, the OEM fluid is petroleum based, was looking for an upgrade from the factory stuff.
Quite a few are using Ravenol FZ on the Mazda forums with great success.
Mazda FZ Fluid is petroleum made by Idemitsu.
Found the info on the back photo of the bottle on Amazon
I was just curious.
