Tried my new Westinghouse generator 7500/9500 - 20 amp last week during a power outage. Plugged in one Samsung Refrigerator/Freezer french door. 10 amps draw. Frig ran fine for about 20 minutes then clicked off due to GFI fault. New heavy duty extension cord, #10 gauge by 25' that ends with three outlets. Generator has two 110 VAC outlets and both did same. Reset the GFI and same. 20minutes and off again.
Wrote Westinghouse and they dais to use an UN-grounded cord. You can't buy an un-grounded extension cord these days.
Wrote back and this time they replied ; it is more than likely due to the multi-outlet-not necessarily the grounded extension cable. Check the total harmonic distortion level (THD) requirement of the Samsung device. Some require cleaner power generators. The WGEN7500DF has a THD of 23%.
Does this make any sense ? Didn't know I'd need an Electrical Engineer to just run a refrigerator on a $1,000 generator.
Samsung RF4287HARS.
Generator Westinghouse Wgen7500DF dual fuel on gasoline 75-- running watts 9500 peak
Samsung RF4287HARS.
