Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
26 registered members (ArrestMeRedZ, blufeb95, carlprop, chemman, Black_Thunder, bbhero, 4 invisible), 1,274 guests, and 44 spiders.
Topics306,079
Posts5,286,950
Members71,596
Oil accumulator to prevent engine wear #5398564 04/09/20 03:32 PM
IMSA_Racing_Fan Offline OP
I remember hearing some number like 90% of engine wear occurs at startup.
Has anyone here seen, heard, or installed themselves a hydraulic accumulator with a solenoid operated valve that shuts off and on with the ignition switch?
2012 Cadillac CTS 3.0
1997 Ford Aspire
1991 Jaguar XJ6
1986 Kawasaki ZG1000 Concours
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398571 04/09/20 03:38 PM
CT8 Offline
Yes and there are also electric primers pumps.. The question is do we really need one? May be for a seldom driven vehicle. I hear lots of stuff and we need to discern what we hear. Usually a maintained reliable engine brand out lasts the vehicle.
2015 F150 2.7
2018 F350 6.2
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398630 04/09/20 04:55 PM
2
2009Edge Offline
2
AMSOIL had one with a solenoid and accumulator at one time.
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398633 04/09/20 04:57 PM
R
ripcord Offline
R
I had a project manager whos late 80s Mustang SVT burned up a couple of turbo's and when he tore one down he found coked bearings. To try to fix the issue he installed an accumulator that released whenever oil pressure fell below a certain point. It was plumbed into T at the turbo's oil line to give it some extra oil pressure while it spun down at shutdown.
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398671 04/09/20 05:39 PM
Marco620 Offline
Apexi Turbo Timers work great. Pull E brake up,set for 5 minutes and pull key out. I think if the car was seldom ran then doing the Lubegard storage additive https://www.lubegard.com/products/free-eze/
I think this also might be a case where a high ester based oil might work really well.
15' Civic r18, 335,000 mi M1 0w30/5w30 & LG Biotech,Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398687 04/09/20 06:07 PM
K
kschachn Offline
K
The majority of wear does not occur at startup, that is a myth. The majority of wear occurs during the warmup phase.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398769 04/09/20 08:32 PM
B
bulwnkl Offline
B
Low-rpm, low-flow, post-start is when the accumulator would be diverting oil from the engine to re-charge itself. So, you’d have pre-oiled, but then have insufficient flow for a while after start-up. Are you accomplishing much with such a system?
I understand the concept here, but if I wanted to spend money and time on a pre-oiler, I’d use an electric pump. That eliminates:
—the need to regularly check or re-charge the accumulators (that was nearly an annual need on some of the tractor transmissions), and
—the diverted oil flow when the engine is already receiving least oil flow.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
