Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
52 registered members (Alain2, 94astro, aba4430, 2009Edge, 4WD, 97prizm, 8 invisible), 1,421 guests, and 46 spiders.
Topics306,035
Posts5,285,292
Members71,572
Page 1 of 3 1 2 3
When did mechanics start using rubber gloves? #5396239 04/07/20 09:33 AM
A
atikovi Offline OP
A
I put on a pair for most anything done on the car except maybe interior work. When I got my first car in the late 70's there was no such thing as mechanics rubber gloves. There was just soap for cleaning up after like Lava or GoJo. When and who got the idea to use medical gloves for auto repair?
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396256 04/07/20 09:41 AM
Chris142 Offline
We were using them as far back as 1996 that I remember.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396257 04/07/20 09:42 AM
sasilverbullet Offline
Don't know but I sure wish I had them back in the early 70's! My body soaked up a lot of nasty chemicals back then...
To me the benefit is not to stay clean, but to keep our bodies from soaking up the chemicals.
03 Porsche 911 Driven DT-40 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 5W-30 & WIX
02 Chevy 5.7L van-GTX HM 10W-40 & WIX
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396307 04/07/20 10:27 AM
R
ragtoplvr Offline
R
OSHA requires personal protective equipment. Most small shops are never inspected unless someone is hurt or worse. But as stated many of the chemicals and used motor oil is carcinogenic. You do not need them on your skin, brake cleaner will dissolve the fat out of your skin, also nasty. No it will not work around your middle.
It is just smart practice.
Rod
Re: When did mechanics start using rubber gloves? [Re: ragtoplvr] #5396314 04/07/20 10:34 AM
javacontour Offline
How about my love handles? Will it work there.
Rod
network down, IP packets delivered via UPS -BOFH
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396321 04/07/20 10:37 AM
I
Imp4 Offline
I
Probably when they realized that so much of what drips on you causes cancer.
At least the smart ones did anyway...
Re: When did mechanics start using rubber gloves? [Re: ragtoplvr] #5396358 04/07/20 11:30 AM
Chris142 Offline
Rod
Darn!
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396376 04/07/20 12:00 PM
Snagglefoot Offline
Gasket remover will take your fingerprints off. Not bad for B&E's but generally not good for you and also your Iphone Touch ID will be out of order for a few months. laugh
If you want the job done right......do it yourself.
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396481 04/07/20 02:01 PM
double vanos Offline
It scares me to think of all the stuff I’ve exposed my carcass to while mechanicing. No varsol? Wash in gasoline. Need to clean out a oil cooler or evaporator? Use Freon 11.
Carb cleaner, both aerosol and bath, brake cleaner, super strength soap cleaners, brake fluid, paint thinner, mineral spirits, every kind of lubricant available in a big maintenance shop along with the aforementioned I’ve worked with without PPE. Darn right suicidal! But back in the day personal safety wasn’t stressed. Example: during a safety inspection the varsol bath was written up for not having a fire extinguisher within 10 feet. No mention of gloves for it.....
My “wake up” moment came when a good friend got a brain tumor. Living in Texas his home shop was air tight so the A/C would work good. Nothing got out and he was doing it all - mechanic and body work. A biopsy of the tumor removed showed it be directly related to the shop. It killed him, took about a year to do it, nothing would stop the reoccurrence of the cancer.
So do I use PPE now? Darn tooting!
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396504 04/07/20 02:15 PM
sloinker Offline
I started using them when Harbor Freight's started popping up and selling them in the early 1990's iirc.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396513 04/07/20 02:30 PM
A
Audios Offline
A
Weve been using them since I started in 2002 at all the major dealers I was at.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: When did mechanics start using rubber gloves? [Re: atikovi] #5396558 04/07/20 03:25 PM
V
vavavroom Offline
V
They SHOULD have been wearing gloves.
[Linked Image from i.etsystatic.com]
Re: When did mechanics start using rubber gloves? [Re: sloinker] #5396563 04/07/20 03:32 PM
A
AC1DD Offline
A
Yes, over the early to mid 90s state health and safety agencies were promoting the use of gloves in automotive repair to prevent
skin from absorbing poisonous chemicals in oil, gas, and other fluids. I do remember some tech, very few wearing cloth black grip style gloves that were commonly sold by the tool trucks back in the mid-late 80s. They seemed to disappear in the early 90s and limited techs started wearing the nitrile gloves
in limited numbers but they became common by the early 2000s. I'd say it was standard to wear them by the mid 2000s.
Re: When did mechanics start using rubber gloves? [Re: vavavroom] #5396571 04/07/20 03:38 PM
P
pandus13 Offline
P
In a Vin Diesel voice: "those shoes would kill you after a full day" (or similar).
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: When did mechanics start using rubber gloves? [Re: vavavroom] #5396595 04/07/20 03:58 PM
L
Lolvoguy Offline
L
Pretty sure I saw that pic in a 1920's "Snap-on" swimsuit calendar.
Also, wasn't that hairstyle common for males in the 90s?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Page 1 of 3 1 2 3
