Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
Memorial Day - Veteran's Cemetery
by JeffKeryk - 05/24/20 07:18 PM
YogiTheCat, StevePLR, BBC_bias, rabblrouzr, Modoi
71524 Registered Users
83 registered members (2015_PSD, AandPDan, alchargo, alarmguy, 53' Stude, ABN_CBT_ENGR, 6 invisible), 2,325 guests, and 25 spiders.
Topics305,837
Posts5,281,227
Members71,524
Turn signals all blinking fast #5389037 03/30/20 12:14 AM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
The car is my 81 MB 240D. Hasn’t been driven all winter, but battery has been kept charging on a float charger. Started up and ran perfectly, AC (R-12 system) kicked right in, all good. Then I put on my turn signal. Fast flashing, though it was maybe a bad connection from sitting... found other side did the same thing. Then I try the hazards - that is fast flashing too.
Pull into the garage and try the hazards again, and find that all four bulbs are lighting just fine! Just flashing fast, like it does when one bulb is out.
This system is very simple - the hazard flasher button has a relay built into it. So when the control stalk is used, it controls that, and of course when the button is depressed, it automatically overrides all four and flashes them. It is a 1970s system at best, and in later cars they segregated the relay form the button. Mine is old tech.
The alternator was putting out 14v, all seemed ok.
So, anyone familiar enough with these relay flasher systems to help me understand just where to start?
Ive checked both taillight turn bulbs, and they both look good, clean and work. Front ones weren’t removed and reseated, but they both illuminate.
Any recommendations on how to break up the system and start to troubleshoot?
Thanks!
Re: Turn signals all blinking fast [Re: JHZR2] #5389038 03/30/20 12:19 AM
O
oldhp Offline
O
Maybe replace the flashers? Maybe check the body ground to frame/battery? Sounds like a grounding problem to me.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Turn signals all blinking fast [Re: JHZR2] #5389041 03/30/20 12:50 AM
CR94 Offline
Are the bulbs less bright than normal?
2011 Toyota Prius now at 110K
Re: Turn signals all blinking fast [Re: JHZR2] #5389042 03/30/20 12:54 AM
V
vw7674 Offline
V
Does it have the bullet type 1970's fuses?
Just spin them in place, all of them, to see if that corrects it.
Happens when German cars sit, contact surfaces of the fuse ends oxidize.
Re: Turn signals all blinking fast [Re: oldhp] #5389058 03/30/20 02:10 AM
A
AC1DD Offline
A
Yes, a increased resistance ground probably from corrosion or a loose connection?
Re: Turn signals all blinking fast [Re: JHZR2] #5389100 03/30/20 06:01 AM
T
Trav Offline
T
As other have said bad ground or a bad flasher, swapping the flasher (if you have an extra) would be my first thing.
Re: Turn signals all blinking fast [Re: JHZR2] #5389185 03/30/20 08:00 AM
Astro14 Online Content
Online Content
I would chase those grounds first. Then clean/check each bulb socket. Perhaps replace bulbs.
This happened to my 1981 240D a few decades back. I can't remember what I found, but I remember replacing that somewhat expensive flasher/hazard switch, and it wasn't the flasher.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Turn signals all blinking fast [Re: JHZR2] #5389210 03/30/20 08:24 AM
A
Audios Offline
A
Probably a bad hazard switch, its al routed through there. Same thing is common with my golf.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Turn signals all blinking fast [Re: JHZR2] #5389211 03/30/20 08:26 AM
A
andyd Offline
A
On my jeeps, the flashers, turn and 4-ways were the same part. OTOH, I don't what my 528e used, the units never acted up.. Fuses and fuse contacts were a constant maintenance issue . Didn't you have an old 3? So you know about those rassen frassen ceramic fuses. I just guessing, by the way flashers work, that it is an internal short in the flasher so that the make and break interval is shorter due to less resistance. Please post a follow up. grin2
Thick oil is better grin2
Re: Turn signals all blinking fast [Re: JHZR2] #5389406 03/30/20 12:26 PM
L
Lolvoguy Offline
L
yeah, no kidding. I'd like to know what caused the issue too.
IME, usually when cars sit in storage (especially older Euro cars) the electronics tend to operate a little "funny".
On my BMW, despite having an all original radio system, it strangely started blowing fuses whenever i'd close the trunk.
I couldn't understand why, so on a whim I decided to take it to my mechanic to see what the issue was.
On the way there, I wanted to listen to some music, so considering I ran out of the 8A fuses, I popped in a 16A to get me to the shop.
Sure enough, when I got there I indicated to problem to them. They struggled to get the radio fuse to blow, but it just wouldn't.
After that I put my 8A back in, and the system has been running fine.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Turn signals all blinking fast [Re: JHZR2] #5389516 03/30/20 02:56 PM
Dave9 Offline
In addition to what's already been mentioned, if the problem persists then see if you can non-destructively open the control stalk switch, do so and clean out any corrosion that's present. Maybe that's not it, but it is one possibility and this would rule that out. After cleaning, put a light coat of dielectric grease on the contacts. If it has tilt steering you might instead (or in addition) have a fouling contact or fraying wire for the connector to that stalk module.
Re: Turn signals all blinking fast [Re: andyd] #5389815 03/30/20 11:28 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Yes, the old style hazard switch, used up to 1981, is an expensive item, and thus a swap of last resort...
Bulbs are good. Pulled them. All work and worked when parked. No contacts looked iffy...
My 318 had regular blade type fuses. These w123 cars I own all have the bullet fuses. I don’t recall if my w126 has blades... I’d assume so.
Re: Turn signals all blinking fast [Re: JHZR2] #5400028 04/11/20 08:51 AM
K
kc8adu Offline
K
if the system flashes by switching the relay whatever they use as a timing element is at fault.
dried out electrolytic cap?
a friends pontiac had a weird issue with clicking when the signals were off.
turned out the relay in the hazard button provide the noise.
and inside that switch is a spiderweb or stamped copper links soldered in several places.
the solder joints had failed.
easy fix(to me).
Re: Turn signals all blinking fast [Re: JHZR2] #5401632 04/13/20 02:56 AM
P
pitzel Offline
P
I know on newer cars, what is often described as 'hyperflash' is an artifact of having insufficient resistance in the circuit, ie: a burned out bulb, a retrofitted LED bulb, etc. Basically they'll use a sense resistor in-line with the power circuit, and if the voltage is insufficient on the sense resistor, the hyperflash is triggered.
I'm never a fan of using the proverbial "parts cannon", but at $3.21 (CAD$) from Rockauto....it'd be pretty silly not to try:
https://www.rockauto.com/en/moreinfo.php?pk=1324298&cc=1192980&jsn=454
edit: Also do a thorough check of the grounding parts. per: http://www.peachparts.com/shopforum/vintage-mercedes-forum/347613-hyper-flash-fast-blinkers.html
