I had a YES warranty through Yamaha and thought I would be covered just like the original factory warranty but found out after I bought it that it excludes so many things as wear parts like individual gears in the transmission, virtually every sensor even though it had electronic coverage and all labor if even one uncovered part was found defective. It also had a little clause that specified that the part had to FAIL, if it had just worn out of spec it was not covered even though it may cause the engine or transmission to not run properly if they could show that there were any signs something was not right and you did not have it fixed on your dime before a failure nothing was covered. After that fiasco I swore off all after market warranties. They know after so many denials people give up and the few that dont get their policy refunded and cancelled.
Oh and like so many other warranty issues much depends on your mechanic and exactly how he phrases the failure. A good mechanic can get a lot of things covered if he wants to.
