Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
95 registered members (4WD, 01rangerxl, 92saturnsl2, Astro14, amblerman, Atrocious, 9 invisible), 2,296 guests, and 56 spiders.
Topics305,923
Posts5,282,817
Members71,537
Page 1 of 3 1 2 3
My 2019 Civic Si oil dilution - Blackstone analysis #5365756 03/02/20 09:34 PM
H
HondaBoyRacer Offline OP
H
well the software "fix" honda issued for the 2019+ civics with the 1.5t didnt fix anything apparently. just got my most recent analysis back from blackstone for my 2019 Si and it shows my fuel dilution at 3.3%! and this oil only had 3k miles on it...
its weird because the oil analysis i had before this one had 35oo miles on it and only had 2% dilution. i dont live in a particularly too cold environment and and i never take short trips. i do let my engine warm up for 5 to 10 minutes in the morning depending how cold it is.
should i be worried guys?
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365762 03/02/20 09:41 PM
P
PowerSurge Offline
P
Your wear metals are ok. But I would keep changing the oil every 3-3500k miles like you’ve been doing. No need to worry as long as the metals stay low.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365764 03/02/20 09:44 PM
PimTac Offline
Your warmups are the cause.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365774 03/02/20 09:56 PM
R
Rand Offline
R
Blackstone typically Under-reports fuel dilution.
Suggestions:
switch to a 30s warmup when possible.. ie if windows arent iced over etc.
Consider using a 0w30 or 5w30- a typical 0w30 is only about 20-25% thicker at 100C than a 0w20 (not 50% as you would assume from 20wt vs 30wt)
Change oil every 3k miles during cold season.. possibly extend out during warmer parts of year.
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: Rand] #5365779 03/02/20 10:01 PM
H
H
Suggestions:
[b][/b]
thats really not good news. ill cut back on the warmups.. what is a 30s warmup?
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365782 03/02/20 10:05 PM
H
H
could the penzoil also be the cause? im at 23k miles and used nothing but pp 0w20 from the beginning. would switching brands help out for this engine?
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365786 03/02/20 10:09 PM
K
kschachn Online Content
Online Content
K
No. Fuel dilution is agnostic to brand.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365788 03/02/20 10:11 PM
W
WagonWheel Offline
W
30s = thirty seconds
How high was the oil level on the stick?
2003 Honda Accord 2.4L 5AT - 153k miles
2006 Honda Odyssey 3.5L EX-L 127k miles (S-VCM)
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365795 03/02/20 10:14 PM
SteveG4 Online Content
Online Content
Suggestions:
[b][/b]
Thirty seconds of warmup... or as soon as the RPM's drop down, take off and drive reasonably until the engine warms up (no lead-footin').
Welcome! smile
Somewhere between Alaska and Wisconsin...
2006 4WD Silverado LT Crew Cab & 2013 AWD Equinox
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: WagonWheel] #5365796 03/02/20 10:14 PM
H
H
you know its strange because i check the dipsick every week in the same spot in my garage and the level did not increase ..at least not enough to be noticeable.
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: SteveG4] #5365804 03/02/20 10:19 PM
H
H
Suggestions:
[b][/b]
Welcome! smile
thanks for that clarification
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365819 03/02/20 10:43 PM
A
AC1DD Offline
A
Wow it's pretty clear that these engines have a serious problem.
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365830 03/02/20 10:52 PM
P
parshisa Offline
P
Nothing to worry about. Use 0/5w30, change it every 5k or so and enjoy the car. These engines are really good
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365836 03/02/20 11:05 PM
M
Mainia Offline
M
No, nothing to worry about.
I have a 2018 lowered Hyundai Kona AWD 1.6T. I live in Minnesota and short trip to work 10 miles. I am on boost more then most. I get 18 mpg in the winter and 22 in the summer. When I bought this car I knew I was going to have problems with fuel dilution.It is just the nature of a small GDI turbo. I bought a 10 pack of tests from JG Lubrication that I use at work and they are a third party to Polaris Labs. Polaris Labs has far better accuracy then Blackstone in fuel dilution. I am at 5% plus. I worked with a oil analysis tech at Polaris Labs that use to race Hyundai's that they had me work with since he knows the brand so good. I run 5w-30 Mobil 1 ESP, I don't care what Hyundai spec for oil since it a mileage spec. I am running far better oil with MB, VW, and Porsche specs that far exceed theirs. Besides the 5w-30 spec Hyundai allows 5w-40 with no specs on what 5w-40.
Polaris labs have 2 fuel dilution tests, the cheap on they stuff down your throat, and the advanced one that you have to make them run AFTER they do the complete testing and you call for a verbal explanation of your test.Then you demand the better test that you demand on the enrollment of your test through there admissions part of their website. LIke.....hey I am sending this in for fuel dilution and you give me the cheap/crap test so now we have to rerun the test because you did not want to run the advanced test in the first place. I called out I basically ONLY send it in because of I need an accurate fuel dilution test...I digress.
My findings through 2 winters and 8 tests with 5% PLUS fuel dilution. ZERO abnormal wear. And from a turbo motor that gets thrashed on daily. Here it is..... "There is nothing to worry about" There is also a Honda 1.5T guy on here that found the EXACT thing after getting all concerned and worried about fuel dilution. ( I see he posted right above my post ^ ) You soon learn fuel dilution is a none issue. Hyundai rough service oil change is 3,750 miles and I change it then, because I have dirty oil with some soot. You pay to play. I was also told about a story about a business owner who had 35 delivery vans that had what they est. was 8% oil dilution, (since accurate tests only go up to 5%+) they did some other tests $$$ that that guy was willing to pay for to get a 8%+ reading. Guess what........no excessive wear issue in any of the vans with long term tracking. That owner finally realized it is not an issue.
I test every other oil change at a local large CAT dealer that has a huge oil lab to watch wear. None yet. I will start doing once a year checks now ( every 3rd oil change ) since everything is going good.
I see some new Hyundai owners getting all freaked and Hyundai switching out high pressure fuel pumps with the same exact outcome and I keep saying to then, "you will have the same outcome after they try to fix your nothing burger" and every time there is fuel in the gas. I gain about 1/2 qt+ in winter within 200 to 300 miles of a new oil change and it then slows down gaining oil and levels of to another 1/4 to 1/3qt through the rest of the 3,500 mile till I change my oil. Since I get high g force in corners and don't have a oil pan with baffles because that would void my warranty I run a bit over full all the time, so I pump out oil when it gets really high about three times in my 3,500 oil timeline. I use an oil analysis pump/jar/tube setup to get it out.
https://www.jglubricantservices.com/images/JGVP01.jpg
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: My 2019 Civic Si oil dilution - Blackstone analysis [Re: HondaBoyRacer] #5365850 03/02/20 11:20 PM
H
H
Suggestions:
[b][/b]
Welcome! smile
Page 1 of 3 1 2 3
