A well placed router I think would have a pretty darn good chance of covering an entire home @3500 sq ft. Then if you have a dead area in one place, you can add a repeater/powerline adapter. All speculation though, all homes are different and this one we have no idea as too its dimensions.
You don't agree that a well-placed router, somewhat central, is still a compromise, albeit probably the best one for somebody not looking to build-out a setup using AP's? Because that's what I was stating. I just indicated that it isn't the route I would go personally because it won't yield uniform coverage. That doesn't mean it won't be reasonably satisfactory for somebody not wanting to deal with having to build-out a system using AP's.
Maybe I should clarify, to me, it sounds like what you are suggesting is way over the OP's head. When I was posting, I was wondering if running a CAT 5 cable would be over his (and many others) head. Without me thinking about it too much, what you posted is over my head at least in the way I am reading it, since he was posting in here, I thought simple is what he maybe looking for, you sound a bit more advanced! ./... and possibly "overkill" without knowing exactly dimensions/structure of his/her home.
Well, I'm not the only one in this thread that suggested using access points
3,500 square feet, unless it is completely open, is a lot to expect full coverage in from any device. We don't need exact dimensions to acknowledge that fact. If it's a bungalow with a 25' width, that puts the length at 140'. He indicated that the house is single level, so unless it is a big square, coverage on one of the dimensions is going to be problematic. You also suggested running ethernet cable to centrally locate the router, which, at that point, you might as well make a couple of runs and use AP's instead if uniform coverage is the goal. At this juncture, the OP has indicated that he's not after uniform coverage, so it's of no consequence.
If one were to use wired access points I would think they need to know about each other so they can all be on the same SSID and you can walk around house moving from one access point to another. Mesh is OK, but performance always suffers with a mesh vs wired access points. However with mesh the performance may still be faster than the connection to the internet.
