Originally Posted by HyundaiAbuser
Originally Posted by Brian200001
Hi friends. I'm a long time reader and first time poster.
Hoping there are a few oil gurus here that can weigh in. I have a 2019 range rover evoque and like many, I would like to change my own oil more frequently than every 16K miles indicated in the manual.
Of course the manual specifies using oil that complies with the STJLR.51.5122 spec which is:
CASTROL EDGE Professional E 0W-20 (Product Code: 468056) $15 per Quart
https://msdspds.castrol.com/bpglis/...018025845100071859/$File/BPXE-A9VG8C.pdf
Ingredients from the Safety Sheet:
- Synthetic base stock. Highly refined base oil (IP 346 DMSO extract < 3%). Proprietary performance additives.
- Distillates (petroleum), hydrotreated heavy paraffinic â¥75 - â¤90
- Distillates (petroleum), hydrotreated heavy paraffinic â¤5
- Distillates (petroleum), solvent-dewaxed heavy paraffinic â¤3
However, I also found this oil for only $7 per quart which complies with the Audio/VW 508/509 spec:
Castrol EDGE Professional LL IV FE 0W-20 (Product Code: 469279)
https://msdspds.castrol.com/bpglis/...5E802582F3006B6939/$File/BPXE-AKE6LY.pdf
- Distillates (petroleum), hydrotreated heavy paraffinic â¥25 - - 1-Decene, homopolymer, hydrogenated â¥10 - â¤25
- Dec-1-ene, homopolymer, hydrogenated Dec-1-ene, oligomers, hydrogenated â¥10 - â¤25
- Distillates (petroleum), hydrotreated heavy paraffinic â¤10
As you can see they are fairly similar but the LL IV FE obviously has more additives/ingredients however:
Both are Castrol Edge Professional
Both have this Titaniam FST (whatever that is)
Both are the same weight.
So although they are not the exact same, does one product or the other appear to be superior? Should I just pay the $15 per quart for the E version or is the LL IV FE product inferior and hence why it is $7 per quart?
Thanks for your input:
Brian200001
2019 Land Rover Range Rover Evoque Landmark Edition
1999 Porsche Boxster
Just a future reference for something this specific you should make your own threat.
completely my mistake i meant thread
