Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
118 registered members (01rangerxl, 762fermeandyou, 53' Stude, 2015_PSD, 69GTX, 390pi, 13 invisible), 2,545 guests, and 25 spiders.
Topics301,888
Posts5,204,618
Members70,796
Removed valve cover, need to move car change oil? #5332064 01/25/20 05:23 PM
M
mazdamonky Offline OP
M
So my protege started making noises which appeared to be due to the timing belt cover coming loose and contacting one of the pulleys. After removal, which required removing the valve cover, I found the timing belt tensioner pulley failed. This means I need to do more work than intended. Normally, after removing the valve cover I would do an oil change, however, I need to move the car about a block to my garage from my parents house so I can do the timing belt job next week. Should I change the oil and change again after the timing belt, or should I just move the car and do the oil after the timing belt?
2018 mazda3 hatch 2.5 26148 miles
1985 rx7 1.1 100k miles
2002 protege 236k miles
1985 rx7 with a 5.0 swap
2020 corolla 750 miles
4 more running cars in yard not mentioned
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332078 01/25/20 05:38 PM
A
atikovi Online Content
Online Content
A
Why? Is it due for one?
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332086 01/25/20 05:49 PM
53' Stude Online Content
Online Content
Wait til repairs are done then change oil.
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332097 01/25/20 05:59 PM
B
BigCahuna Offline
B
Slap the valve cover back on and drive it a block. Do what needs to be done with new gaskets , then change the oil if needed. Try not to over think it.,,,
Re: Removed valve cover, need to move car change oil? [Re: 53' Stude] #5332107 01/25/20 06:07 PM
spasm3 Online Happy
Online Happy
+1
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332189 01/25/20 07:45 PM
L
Leo99 Offline
L
I've never connected removing the valve cover with changing the oil. I don't understand the connection.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Removed valve cover, need to move car change oil? [Re: Leo99] #5332209 01/25/20 08:06 PM
M
M
My understanding has always been removing the valve cover introduces extra contaminates to the top of the engine/engine oil and oil should be changed.
It is about due for an oil change. Its been around 8000 miles since I last changed oil. It burns a quart at an average of 1k miles depending on driving. Mostly changing to change the filter. Probably doing a valve seal job while I am in there to try to reduce the oil burn.
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332213 01/25/20 08:08 PM
Dave9 Offline
Change the oil then hook it up to a donkey to pull to your place, then change the oil, then have donkey pull it to your place, then change the oil, then unhook the donkey, then change the oil, then send the donkey home then change the oil then do the timing belt then change the oil.
... or just move it home, do the timing belt, then change the oil once since it only needs it once. smile
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332247 01/25/20 08:47 PM
A
Online Content
A
Well, I usually wash the engine before pulling the cover, but anything that falls on top of the engine isn't coming out with that oil change anyway.
Re: Removed valve cover, need to move car change oil? [Re: Dave9] #5332350 01/25/20 11:09 PM
T
TheLawnRanger Offline
T
This is the only reasonable solution.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Removed valve cover, need to move car change oil? [Re: BigCahuna] #5332371 01/25/20 11:44 PM
Chris142 Offline
This. Then run it with the old oil and filter to allow the filter to pick up any contaminants then change the oil and filter.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Removed valve cover, need to move car change oil? [Re: mazdamonky] #5332587 01/26/20 09:58 AM
M
mpack88 Offline
M
Just put the cover back on and drive it where you are changing the belt. Its not going to hurt a thing. Unless your belt comes off due to the failed tensioner.
Re: Removed valve cover, need to move car change oil? [Re: BigCahuna] #5333588 01/27/20 10:59 AM
W
WyrTwister Offline
W
Yep .
Wyr
God bless
